vararam power duct worth it?
my mods are, Vararam B2, cam, headers, no cats, corsa, tune, ect...
since i already have the B2 setup, i was wondering if the power duct is worth the $100?
comments? suggestions?
When ever you alter the factory tune by bolting on something or changing something that allows more air to flow thru the engine, the PCM will do what its designed to do to and add or remove CLOSED LOOP fuel by adding or subtracting thru Long Term Fuel Trims (LTFT) to maintain 14.7:1 part throttle AFR. It can ONLY adjust +- 25% The further away that the LTFT's get from zero, the less efficient your engine becomes in closed loop. Closed Loop fuel trims being way out of spec also effect your open loop Power Enrichment (PE) tables
The reason you Butt O Meter feels HP increases when you hammer it, is that the PCM goes into OPEN LOOP and that added air flow makes a change in the Power Enrichment (PE) tables AFR. Hopefully it helps your PE AFR get closer to 12.7:1 thus more power. Sadly, sometimes it doesn't improve PE AFR and you can even see a power loss until tuning is done to correct the LTFT, PE AFR's and adjust timing and MAF tables.
My ported TB made significant improvement in throttle response. Cant tell you how HP my ported TB alone gave me but my throttle response was a lot better.
Add headers, efficient mid pipe, cold air intake, better intake (LS6 if you don't already have one) and a ported TB and then have it tuned and that will make a nice difference.
