how Low will It go
Old Mar 12, 2002 | 11:41 AM
strypr's Avatar
strypr
Default how Low will It go
when lowering my car how low can i expect it to go using the stock hardware?
Old Mar 12, 2002 | 11:44 AM
D. Brawl's Avatar
D. Brawl
Default Re: how Low will It go (strypr)
That PT looks great. Those are some of the coolest flames I've seen.
I think you can get about a inch lower. I'm probably wrong tho. I'm sure someone will correct me.
Old Mar 12, 2002 | 05:58 PM
Patches's Avatar
Patches
I took mine as far as the stock bolts would go without cutting the bushings. It went down almost exactly 1".
Ed
Old Mar 12, 2002 | 10:51 PM
Viprklr's Avatar
Viprklr
Default Re: how Low will It go (Patches)
If you apply a jack to the leaf spring (I believe) it relieves the pressure on the bolt and you can turn it by hand (the front). My question is, will the bolt stop turning at some point? Mine just keeps going. Should I be afraid to keep turning it? Thanks! :cheers:
To how Low will It go
