PIN Locations
Old Mar 25, 2010 | 03:07 PM
jimish's Avatar
jimish
Default PIN Locations
I need to locate pins 31 and 71 on the blue plug to the ECM. The computer has A,B,C and D, with arrows to each plug, but no numerical markings.
Old Mar 25, 2010 | 03:23 PM
lucky131969's Avatar
lucky131969
I'm assuming for an 02?......not used.
Old Mar 25, 2010 | 03:56 PM
jimish's Avatar
jimish
Exactly what I needed. Thank you so much. I understand by grounding pin 31 the trans goes into manual mode, and 71 will put it into the second programming mode (4 wheel drive)
Old Mar 25, 2010 | 04:12 PM
dougbfresh's Avatar
dougbfresh
How can they do anything if they are not used?
Old Mar 25, 2010 | 05:46 PM
lucky131969
Well that's interesting. On what GM model is that used?
Old Mar 25, 2010 | 07:36 PM
jimish's Avatar
jimish
The EFI Live program calls the second program,4 wheel drive the performance program and says to momentarily connect to ground to use whatever you have programmed in. Likewise it says to use a second switch and momentarily connect to ground to go into manual mode.
Old Mar 25, 2010 | 07:37 PM
jimish's Avatar
jimish
By the way, its an 02 drivetrain mounted mid engine in a 66 Corvair.
To PIN Locations
