FOB Problems
Old Mar 25, 2010 | 03:08 PM
Varmit's Avatar
Varmit
St. Jude Donor '08
Default FOB Problems
I have a '99 C5. Yesterday all of a sudden the FOB stopped working New FOB less than a year old. No problem changed the battery, still did not work. Tried to reprogram the FOD by going through the DIC process, still no workie. Finally tired to hold down both the lock and unlock buttons as per the manual still no workie, Went and got a second new battery changed with gloves, did the entire process again...no workie. Tried the second FOB same results. Is there a fuse in the car or a module that I can check out??
TKS
Old Mar 25, 2010 | 03:25 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Check fuse 27 in the passenger side footwell fuse box.
Old Mar 25, 2010 | 04:17 PM
Varmit's Avatar
Varmit
St. Jude Donor '08
Mark
Thanks will do
Old Mar 25, 2010 | 05:09 PM
c5blkvetteguy's Avatar
c5blkvetteguy
This is the first spring in six years I have NOT had to replace the battery in my fob. For some reason my fob battery stays in hibernation with my car.
Old Mar 25, 2010 | 05:35 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
As long as your TPS's are working that rules out your receiver. They both work on the same frequency.
The other thing, your car battery. If not fully charged it can cause problems programming the remotes.
Old Mar 25, 2010 | 08:20 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
pop open the fob and look very very closely at the solder points on the small black square sort of off by it self.
Usually the solder points come loose and cause this issue.
Old Mar 25, 2010 | 09:49 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
does sound like a fuse with it happening to both fobs
Old Mar 26, 2010 | 12:00 AM
Varmit's Avatar
Varmit
St. Jude Donor '08
Have not had the chance to pull the fuse, I'm hoping that is it.
Old Mar 27, 2010 | 01:41 AM
Varmit's Avatar
Varmit
St. Jude Donor '08
pulled the fuse it is fine, the TPMS works so it is not the module. ?????
Old Mar 27, 2010 | 04:55 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Did you check the voltage on your car battery?
There is one more thing to try. If you have a vette buddy with a 97-99 ask him to let you try to program his remote to your car and see if it works.
Old Mar 28, 2010 | 12:35 PM
Varmit's Avatar
Varmit
St. Jude Donor '08
finally got it to reprogram. Seems to be working fine now, thanks for the input guys.
To FOB Problems
