Pilot bushing or bearing?
Old Mar 25, 2010 | 05:07 PM
Snidley's Avatar
Snidley
Default Pilot bushing or bearing?
Which is the preferred one?
What comes in the car stock?
Replacing the clutch on Saturday with a Monster, and it came with a bearing.
If all is running good now, does it need to be changed? I know, since its all opened up, its a good idea to change it.
Steve
Old Mar 26, 2010 | 02:24 PM
waddisme's Avatar
waddisme
I bought the kevlar bushing to put in mine then changed my mind. But if I had to do it all over again, I would have put it in. From what little is out there now, it seems to be a little more durable than the bearing. Plus I think the brass bushing is less than the bearing itself. Either way, it is good to replace it while all is out. Cheap insurance. If you do the bushing, post a thread about how it does. HTH.
Old Mar 26, 2010 | 03:50 PM
corvettebob1's Avatar
corvettebob1
OK, I've seen other threads in the past asking this same question so I will answer it from a transmission design engineer point of view.
The bronze bushing was used for many years with great success mainly because it was replaced with every clutch change ~25-50,000 miles.
It also tolerated misalignment very well between the bell housing and block at lower RPM levels.
Now we get up to 1997 and machining tolerances are greatly improved and so are the materials used in clutches so the alignment issue goes away and life span of the clutch improves greatly and the ability to sustain higher RPMs.
So the need for a better pilot bearing is created and thus the introduction of the roller/ball bearing.
So now my question is why would you replace a more durable bearing with a bushing that will wear out before the clutch?
Old Mar 26, 2010 | 04:42 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Stick with what is known to work. The only other thing I would add, be careful removing the old one and take note as to how far in the current bearing is and get the new one in the same depth. Hope your clutch change goes well for you.
Old Mar 26, 2010 | 05:25 PM
WKMCD's Avatar
WKMCD
If the shaft from the torque tube is worn or buggered the Kevlar bushing is the way to go.
Old Mar 26, 2010 | 08:16 PM
Carcass's Avatar
Carcass
To Pilot bushing or bearing?
