Is My Oil Pressure Too High?
First off, cars are engineered for ease of manufacture, not repair.
If they were engineered for repair, GM would have created a simple access port to reach the oil pressure switch without removing the intake manifold. Trust me, no engineer would ever spec that much work just to replace a switch.
That said, the Service Manual procedure is often, but not always, the most expedient or even the best way to solve a problem. The oil pressure switch is an excellent example of manufacturing engineering coming into conflict with repair engineering.
Creating the should-have-been-there access port turns the $500/4-hour job into the 20 minute $0 job it should be.
I'd like to know how many people experience downstream problems related to fuel/electrical/emissions issues from repeatedly pulling the manifold.
St. Jude Donor '08-'09-'10
Second off, if you read the forum much on the subject no one seems to be experiencing fuel/electrical/emissions issues from repeatedly pulling the manifold.
If you are having both these issues perhaps automotive repair is not something you are suited for.
You may be a super wrench but most people aren't and don't want to take on pulling the manifold when there's an easier and faster solution.
I know this is true when I read the hundreds of posts about relocating the switch, installing modification kits and creating access ports.
Still, I'm glad you have success with pulling it and there's certainly nothing wrong with the approach.
What I have that allows me to be able to accomplish some of the more basic maintenance and repair issues is an ability to read and understand a service manual as well as technical articles and forum posts.
As I have said many times before, if you have the skill to PROPERLY cut an access hole and reseal it so that engine compartment air does not enter the passenger compartment then you certainly possess the skill to remove the intake manifold and do the job properly.
The fact that I am not a super wrench and able to accomplish the task proves my point. Here is the finished product:
I was able to do this in 2.5 hours with only hand tools. Should I ever need to replace the sensor again it would now be a 5 minute job, faster than the hole method.
