DRL, blinker, relays problem
Old Mar 27, 2010 | 03:16 PM
Gbannish's Avatar
Gbannish
Default DRL, blinker, relays problem
Hi,
I have the following symptoms:
-front parking lights do not turn on (rears do)
-If left blinker is on, the left rear blinks, right rear does not, and both front blinkers blink.
-If right blinker is on, the right rear blinks, left rear does not, and both front blinkers blink.
-With engine on, an audible repetitive clicking can be heard from the instrument panel. It appears to be coming from relays 38 and 40, since I can feel these two relays as they click. They are the DRL/blinker relays.
-If I turn my blinker on, either left or right, the relays stop clicking, and both left and right blinker arrows start flashing. Once the turn is complete, the relays start clicking again.
I replaced every exterior bulb except backup lights and right rear light. No change.
Last week my fog lights wouldn't work until I pulled fuse #2. I'm thinking I have some weird gremlins going on here. Not sure what to try next.
Regards,
Greg
Old Mar 27, 2010 | 06:09 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You most likely have a failing steering column Multi function switch. Very common issue. You can also cycle the emergency flasher switch 10-20 times and see if that has any effect on the symptoms.
Heres a post for you:
- C5 Multifunction Switch repair - http://forums.corvetteforum.com/c5-t...f-replace.html
Hope this helps.
BC
Old Mar 27, 2010 | 06:26 PM
Gbannish's Avatar
Gbannish
Much thanks, I'm sure that will be failing in the near future. Luckily, I found the problem. It was splice pack 102 (SP102), located near the right headlamp and splicing wires for the front turn signal, DRLs. I had taken apart last weekend to clean it up in hopes of repairing a fog light problem, and must not have put back together well enough. After pushing the connector together harder, everything now works.
It seems like alot of people can read the schematics in the factory manual, I'm still struggling to understand fully, but slowly getting there. Although I wasted another saurday, I did save big bucks had I brought into the dealer so that alone makes it worthwhile!
greg
Old Mar 27, 2010 | 07:25 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Greg
If that SP continues to give you issues, inspect it again and look for female pins with poor connections. Theres a small metal tong in each female pin that makes TIGHT connections with the male pin. Some times, that tong gets bent back and thats where the poor connection issues begin.
Ive also found that it a good idea to add some ANTI CORROSION compound to those non water tight connectors. I DO NOT recommend using Dielectric grease. Here is what I use but there are other compounds for this specific purpose:
Old Mar 28, 2010 | 07:22 AM
Gbannish's Avatar
Gbannish
Thanks much Bill, I think you've hit the nail on the head. When I cleaned out that splice pack last weekend I added a small amount of dielectric grease, later finding out that at least someone else here does not recommend (only for bolt on electrical connections). That probably contributed to the poor connection. I'll look into something better such as the corrosion X cans you mention.
Thx,
Greg
To DRL, blinker, relays problem
