Crankcase vent line, need vacuum?
Old Mar 27, 2010 | 07:52 PM
USCGREEL's Avatar
USCGREEL
Default Crankcase vent line, need vacuum?
Well I broke a belt on the blower yesterday and now I am going thru the hastle of trying to find which belt I need. While I had the blower off I noticed a good amount of oil residue on the pipes and blower fins. I want to make a catch can but I am curious why we have to even have a line going to the intake tract? Why not take the line that I have going to my intake and put it to a catch can, and all the excess pressure/vaccum be vented to the atmosphere rather than in the intake. Please let me know if this isn't do able and I am way out in left field.
This is how my lines are currently ran, then the bottom of the T runs to the intake blower tube.
This is what I want to make. One line goes in and done.
Old Mar 27, 2010 | 07:56 PM
slow ride's Avatar
slow ride
If you want to run it without PVC hooked up I'd suggest you run it like you have it, but run two lines instead of teeing two to one. More room for blowby to get out of the crankcase.
Old Mar 27, 2010 | 08:15 PM
lucky131969's Avatar
lucky131969
If you've got oil all over the impeller, than you have a bearing seal bad in the blower. I'm surprised the dipstick stays in, considering the way you have it hooked up.......too restrictive......and quite useless as is.
Old Mar 28, 2010 | 12:12 AM
USCGREEL's Avatar
USCGREEL
Like I said, I dont have any idea about these lines....I was told by my shop I go to (G Force motorsports) for a tune, to run it like this. Slow ride, good idea, I will get rid of the T when I go to do it.
Old Mar 28, 2010 | 01:34 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
I've got a catch can on my LS6 and I'm thinking about only running the valley breather to the intake (through the can first).
If I can cap the valve cover nipple, and the line it goes to on the throttlebody... I can make the clutter even less by removing that line from sight. My engine is almost ready to go back together... I'm finishing up polishing one of the cylinder heads this weekend.
To Crankcase vent line, need vacuum?
