A4 Trans Cooler Plumbing
Old Mar 29, 2010 | 12:10 PM
yakisoba's Avatar
yakisoba
Default A4 Trans Cooler Plumbing
I rigged up a trans cooler in series with the built in cooler in the radiator. The hitch is that the stock hoses are this weird sort where part of it is rubber and part is hard pipe. The bends in the hard pipe are now in an awkward place. What sort of fittings can I replace the ends with to allow better flex in the hoses so I can tuck everything out of the way?
Sorry if this is a bit vague, but if you've worked with the trans hookups on the C5 you will know what I'm talking about. Thanks.
Old Mar 30, 2010 | 06:58 AM
clif's Avatar
clif
St. Jude Donor '09-'10
MY mechanic, just slid a rubber hose over the fittings on the factory lines at the raditator. Then again, I removed the radiator from my tranny cooling system. I only use my B&M cooling system, which is mounted in the driver's front fender.
