Windows rubbing on 98 C5 convertible top
Old Mar 12, 2002 | 11:30 PM
batsallover's Avatar
batsallover
Default Windows rubbing on 98 C5 convertible top
Anyone out there with a convertible notice that upper rear corner of the driver and passenger windows rub the convertible top? It only happens in the winter months on my vette and it has frayed the drivers side corner of the convertible top. Any solutions or advice in adjusting the top to eliminate the rub? The dealer says the top is not adjustible. Thanks for the help. :D
Old Mar 12, 2002 | 11:43 PM
123vette456's Avatar
123vette456
Default Re: Windows rubbing on 98 C5 convertible top (batsallover)
Try this sitehttp://www.johndennington.com/ should have all instructions re window adjustments
Old Mar 12, 2002 | 11:46 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Common problem,the solution is to adjust the windows slightly foward.The windows on the C-5 can be adjusted foward,back,up,down,in,out,however you prefer :yesnod:
To Windows rubbing on 98 C5 convertible top
