Carpet Glue
Old Mar 30, 2010 | 08:00 PM
GeorgieMporgie's Avatar
GeorgieMporgie
Default Carpet Glue
I have a 99 coupe and the carpet next to the gas pedal is sticking up and getting in the way of my pedal to the metal driving. What type of glue should I use that will dry quickly and hold the carpet and insulation down. It's sticking up pretty good so whatever glue I put on it I'll also have to add some weight to hold the carpet down until the adhesive dries. Any advise will be appreciated. Thanks.
Old Mar 30, 2010 | 08:13 PM
MacD50's Avatar
MacD50
Instead of using an adhesive, why not try double-stick carpet tape. It works well but can be removed if need be. Just a thought.
Old Mar 30, 2010 | 08:48 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I would remove the carpet and use an EPOXY adheasive to re-seal the joint.
BC
To Carpet Glue
