What does this plug plug into?
Old Mar 30, 2010 | 09:34 PM
97Rob's Avatar
97Rob
Default What does this plug plug into?
Removed all the carpet to install insulation. There is a sub woofer amp and other stereo equipment that was professionally installed. This particular plug was wrapped w/ all the stereo wires, but is part of the original wiring of the car. Before the end of the plug, it branches off to the rear interior light and the electric hatch release, this is the passenger side. Anyway, apparently I unplugged it while removing carpet stereo equipment etc. I do not want to start taking things apart to find the female end of this plug. Your help is appreciated.
Rob Edwards
Old Mar 30, 2010 | 10:13 PM
rcs128's Avatar
rcs128
I'm not 100% sure but I think it might be the plug for the car's original CD changer.
Old Mar 30, 2010 | 10:38 PM
byronhunter's Avatar
byronhunter
Does it match this?
Remote Playback Device-CD Changer
Connector Part Information
12047531
10-Way F Micro-Pack 100 Series (BLK)
Pin
Wire Color
Circuit No.
Function
1
BRN/WHT
367
Remote Radio Signal-LH Audio
2
DK GRN/WHT
368
Remote Radio Signal-RH Audio
3
BLK/WHT
372
Remote Radio Return-Audio
4
BARE
514
Drain
5
ORN
440
Battery Fused Feed
6
Not Used
7
BLK/WHT
351
Ground
8-9
Not Used
10
DK GRN
835
Entertainment & Comfort-Data Buss
Old Mar 31, 2010 | 06:22 AM
97Rob's Avatar
97Rob
Thats it. Where does it plug into? There is a CD changer in the right side cargo hull, and there is a amp in the center cargo hull. Thanks for the help.
Old Mar 31, 2010 | 06:48 AM
97Rob's Avatar
97Rob
Think I got it. This would power the changer?
Old Mar 31, 2010 | 07:11 AM
WKMCD's Avatar
WKMCD
Hey Rob,
How's the car running? I haven't spoken with William in a while. I really need to give him a call to say hey.
Old Mar 31, 2010 | 12:10 PM
97Rob's Avatar
97Rob
Originally Posted by WKMCD
Hey Rob,
Car is running great. You ought to make a trip to N. Carolina.
Old Mar 31, 2010 | 03:32 PM
Ron Dittmer's Avatar
Ron Dittmer
The wire harness with the connector in-question was installed by the factory to support the 12 CD changer option. It provides power, speaker inputs, and controls for the stock radio up front to control it.
If you don't plan on installing a stock CD changer, simply leave it tucked away out-of-sight. If you ever sell the car, the next owner will appreciate it if he wants to install the stock changer.
Old Mar 31, 2010 | 07:02 PM
97Rob's Avatar
97Rob
Thats what I needed to hear. Thanks alot.
Old Apr 1, 2010 | 07:34 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
I would have thought bryonhunter provided everything that you needed to know, with his reply. It made good sense to me.
Old Apr 1, 2010 | 03:23 PM
97Rob's Avatar
97Rob
[QUOTE=Quicksilver Vert 01;1573615868]I would have thought bryonhunter provided everything that you needed to know, with his reply. It made good sense to me.[/QUOTE]
You are not me!
To What does this plug plug into?
