Information on changing a flat tire?
Old Mar 31, 2010 | 09:07 AM
raymondh's Avatar
raymondh
Default Information on changing a flat tire?
Does anyone have any information or links on how to change a tire on a c5 vette. For instance, is a jacking puck "required"? The proper place to use a jack, that kind of info. Thanks in advance.
The search feature worked fine, thanks for the comments. Guess I was a little stressed and was looking for immediate gratification. As it turns out, I was able to pump the tire with enough pressure to get down to the tire repair store. ***interesting, and I discovered there is no jack in the car (z06) and no way for me to replace the tire myself** I sure would like to have a jack though. Anyone know where I can pick one up. Also, anyone know if the rear tires on a standard c5 will fit on the rear of a c5z06?
Old Mar 31, 2010 | 11:13 AM
fixvet's Avatar
fixvet
Not trying to be lazy here, but this has been covered hundreds of times here on the forum. My motto to every member is, try to help yourself first by using the search box above, and you'll get alot of replies.
Good luck,
Old Mar 31, 2010 | 11:31 AM
dougbfresh's Avatar
dougbfresh
I just use my Motorcycle jack in the middle of the car to get it up high enougng doe my floor jack which I get under the front crossmember to rais the front, I can get my floor jack under the rear crossmember without the M/C jack.
Old Mar 31, 2010 | 12:01 PM
Jewjenk's Avatar
Jewjenk
USER ERROR,
Now to correct this, get down on the floor, look under the car, see the jacking points, get a jack, lift carefully.
You are supposed to have run flats, unless they are changed, now if you found a spare and no jack. That is because there is supposed to be no SPARE.
Or take it to a shop and hope they lift it correctly without damage...
But seriously, as said before, this has been covered a zillion times, so stop. and do a search..........before posting.
I love to help, but I can't help you brush your teeth if you don't know what kind of brush to buy...........
Old Mar 31, 2010 | 12:04 PM
lucky131969's Avatar
lucky131969
Originally Posted by Jewjenk
You are supposed to have run flats, unless they are changed......
....or if it's a ZO6.
Old Mar 31, 2010 | 12:17 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Some people also have whats called an owners manual............
Old Mar 31, 2010 | 01:33 PM
dougbfresh's Avatar
dougbfresh
Just for GRINS I looked in my owners manual and there is NOTHING about CHANGING a tire (at least in the 2001 version). They talk about flat tires but not about CHANGING one.
Old Mar 31, 2010 | 03:47 PM
Jewjenk's Avatar
Jewjenk
True........
Old Mar 31, 2010 | 03:49 PM
Jewjenk's Avatar
Jewjenk
True again.........----USER ERROR----
Old Mar 31, 2010 | 04:12 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Ray, this should answer most of your questions. The pucks are not absolutely necessary if you are careful with the placement of the jack.
To Information on changing a flat tire?
