Help with wiring in Nitrous Outlet N20 controller
Old Apr 2, 2010 | 07:47 PM
Ksths2's Avatar
Ksths2
Default Help with wiring in Nitrous Outlet N20 controller
I'll make this short as possible
I got a 61001 Single stage N20 controller w/ TPS, WOT, and gear lock out from Nitrous Outlet but i need confirmation on a few things as i'm trying to finish up the wiring.
1) Trying to find the TPS wire i need to go the blue wire on the handheld controller (this feeds the controller for fly by wire TB's)
2) I need to know how to get the proper TACH signal it calls for, it says to go off of the coil pack input wires but not sure which wire that is (this feeds the controller for the window switch)
Thanks!
