Rattle When Taking Off
Old Apr 3, 2010 | 10:03 AM
squidnut's Avatar
squidnut
Default Rattle When Taking Off
In my 01 vert when I take off as normal I get a rattle. If I take off fast I do not get it. It is coming the area of the tranny. When it is in nuetral and just idling you can barely hear it but can feel it in the shifter. When at speed no problem. Cant hear it and cant feel it. Thinking clutch. Ahh and it only has 41,000 miles. Sounds a little premature for a worn out clutch. Have no codes at all.
Old Apr 3, 2010 | 10:15 AM
Mtlfusion's Avatar
Mtlfusion
Throwout bearing. cheap part, but have to open the tranny.
Old Apr 3, 2010 | 10:45 AM
lucky131969's Avatar
lucky131969
So you're saying you have no idea where the throwout bearing is, huh.....
Old Apr 3, 2010 | 10:48 AM
lucky131969
I'm assuming you know the transmission is in the rear of the car. If so, and the noise seems to originate from there....I'll give one possibility.
1) Loose exhaust hangers on the midpipe.....they bolt to the rear bell housing.
Old Apr 3, 2010 | 11:27 AM
Mtlfusion's Avatar
Mtlfusion
I meant in the clutch
need to change mine, what other things should i check out for whilst in there???
Old Apr 3, 2010 | 11:48 AM
lucky131969
There you go You'd be surprised how many don't know the tranny is in the rear on a C5. With a clutch change, you can change out the flywheel (or have yours resurfaced)...then have the assembly balance checked. Change out the slave(throwout bearing is included with the assembly), pilot bearing,and install a remote bleeder. Disassemble the torque tube to inspect the torque tube bushings for cracks. I purchased new exhaust manifold studs from the dealer just in case. Typically, a little heat will aid in the removal. Also, make sure you have a clutch line disconnect tool.
Old Apr 3, 2010 | 12:00 PM
Mtlfusion's Avatar
Mtlfusion
Thank you!!! How much and where can I find a pilot bearing? Is a torque tube bushing expensive? I might as well change it while in there..
I tilt my : to you for your advice, I'm sick of the throwout bearing's "rattling"
Old Apr 3, 2010 | 12:34 PM
lucky131969
Pilot bearing is cheap..available from the dealer. Do a search for torque tube bushings....lot's of discussion, part numbers, etc.
Old Apr 3, 2010 | 09:43 PM
littleredrocket's Avatar
littleredrocket
Are we sure that there is anything actually wrong? If I remember correctly, when I bought my 2001 new, the video or manual said something about noise like the OP described as normal. My car now has 15k on it and has made a similar noise since new. I thought that it may be die to the torque tube--but it's been almost 10 years now so my memory may not be so good!
Old Apr 4, 2010 | 02:01 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Mine rattles. But I know why. In my case it's the added weights on the Centerforce pressure plate. Other rattles I've heard can be loose guts in the cat converters. As Lucky said loose exhaust hangers.
If you plan on replacing just a pilot bearing or a throwout bearing you better do some reading. You would have to be on the insane side to do all that work for a $15. pilot bearing, or a $129. slave and throwout bearing. It's an all or nothing labor intensive job. Minimum 10 to 12 hour job. 3 days if you run into the normal type of annoyances that love to pop up.
Old Apr 4, 2010 | 10:34 AM
squidnut's Avatar
squidnut
so the rattle may be a normal thing. Like I said it does pull like a champ when I get into it and there is no rattle. Thanks for all the info and for staying on track there lucky. Replacing exhaust soon so I can rule out the cat guts.
Old Apr 4, 2010 | 02:02 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Both of the C5 6 speeds I have owned give me a little rattle if I lug it as I let out the clutch in first gear.
Old Apr 4, 2010 | 11:19 PM
scottsdalecessna's Avatar
scottsdalecessna
mine rattles at takeoff also rattles if i shut the car down in neutral with the clutch pedal released. the owners info addresses it.
Old Apr 8, 2010 | 03:34 AM
Rohan's Avatar
Rohan
I had that same problem and it ended up being loose exhaust. I put my new B and B on this weekend and tightended everything up and the problem went away. You wouldn't happen to have those little chrome exhaust tips would you? Those things are notorious for loosening up and causing a rattle back there which as you know by now is right behind your tranny area. Before you go spending a lot of money (unless you just want to) check the small stuff first.
Old Apr 8, 2010 | 10:45 PM
squidnut's Avatar
squidnut
thank you for the info guys. Jacked my back up trying to be young again so when it heals I will check all the little stuff first. Not into spending cash I dont have to.
To Rattle When Taking Off
