Remove Key 10 seconds post recall questions.
Old Apr 27, 2010 | 11:08 AM
barberben's Avatar
barberben
OK gentlemen I believe I have the car fixed! The green wire that I had pulled out of the harness was actually an easy fix. I was able to re-use the connector that it pulled out of, re-crimp it, and re-install it in the correct harness slot. As far as the "Remove Key" and "Service Column Lock" messages, I re-installed my CLB and removed the battery from the car, and charged it overnight. LOL! when I checked the voltage on the battery this morning it read 14.1 volts, I said to myself; "If that doesn't do it, nothing will!". Re-installed the battery, cranked the car, and NO error messages AT ALL! I haven't actually driven the car yet, because the dash is still torn apart, but I'm sure it won't be a problem. Thanks again for all the help you guys have given me.
