Disappearing Codes on Sick Z06
Cam $280.00 ByUnSpeed http://www.byunspeed.com/product_inf...roducts_id=850
Spring Kit $255.00 ByUnSpeed http://www.byunspeed.com/product_inf...roducts_id=826
Hardened Pushrods $105.00 ByUnSpeed http://www.byunspeed.com/product_inf...oducts_id=7060
Gasket Kit $61.95 ByUnSpeed http://www.byunspeed.com/product_inf...oducts_id=4770
Oil Pump $99.95 Lingenfelter http://www.lingenfelter.com/mm5/merc...&Category_Code
Timing Chain $49.95 Lingenfelter http://www.lingenfelter.com/mm5/merc...egory_Code=C38
VaraRam -$325ish
Tune -$300-$400ish[/QUOTE]
Alright, guys, I am on the fence about this cam swap. My '02 Z06 is all stock and has the broken valve spring listed in this post set. With 85,000 miles, am I crazy to not go ahead with a timing chain and oil pump replacement along with a cam swap? I don't necessarily need more HP, but if people claim that the chain is due to fail, I think I should go ahead and replace it, which leads to the cam/pump swap.
What do you think? Am I looking down the barrel of a loaded gun not going ahead with the chain replacement?
VaraRam -$325ish
Tune -$300-$400ish
If you are happy with the way the car runs, and feel the HP is adequate......then leave the cam alone. How soon the chain will meet it's demise has a lot to do with how you drive the car. There is a huge difference between a street driven car, and one that does auto-xing. If you want a piece of mind, and more HP is not your goal, change out the pump, chain, and springs.....and enjoy your car.
