I bought some ccw505a wheels from a forum member, 19x10 in the front, and 20x11 in the back with 3" lip on the rear. I'm having an issue with clearance on my stock caliper... the wheel is hitting it.
I was talking with John from ccw and he mentioned that it may be an issue with my brake pads being thicker. I just had some hawk hps pads installed last monday. Can having thicker pads cause the caliper to stick out further causing this clearance issue? If so, are the stock pads or z06 pads thinner than the hawk hps pads?
