Tire fitment question
Old Apr 7, 2010 | 11:13 AM
Dream Tire's Avatar
Dream Tire
Default Tire fitment question
Hey guys,
I have a 19x11 Modular Concept 3pc wheel on the rear.
Rim outer to outer lip measures 12 inches.
The distance between the frame and the inner fender lip is 12.5
Now, if I mount a 305/30R19 measuring 12.3 I got zero room.
The car is also going to be lowered. I test fitted a 325/30 that I had lying around and that stuck out half inch plus it hit the frame pretty good.
I know that alot of guys here run 305s in the rear. Do you have any fitment/rubbing issues?? According to the numbers its too close.. Abviously I need more than 1mm clearance between the tire and the frame.
unless I put 5 mm spacers on the rear. Which will make them stick out. But I shouldnt have that much travel for it to hit.
Thoughts?????
Old Apr 8, 2010 | 06:40 AM
dieseldave56's Avatar
dieseldave56
Default Wheel offset?
Ok, what is the wheel offset? your issue is not if the tire /wheel combo fits the wheel well but axle hub mount to inside suspension and out fender lip. For that we need the wheel diameter/width and offset. Plug in the OEM rear wheel/tire combo to this link and experiment.http://www.rimsntires.com/rt_specs.jsp?postId=906
Old Apr 8, 2010 | 11:50 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I'm running 305-30-19 in the rear with my CCW's. It is close to my fenders for sure but not hitting the fender when I hit bumps.
I was rubbing a little on my inner fender on my drivers side but that was because my rear cradle was not centered. Many C5/C6 cars have this issue. I have since fixed this issue with a little tweaking. See below.
http://forums.corvetteforum.com/c5-g...the-other.html
Toque
Old Apr 8, 2010 | 03:45 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
I have C6 Z06 wheels 19x11 and run 305/30 Invos. Don't remember the offset, but I have no rubbing and my car is lowered!
To Tire fitment question
