Baer Brake Systems Sale
Old Apr 7, 2010 | 01:33 PM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
Default Baer Brake Systems Sale
We have finally added our Baer Brake section to the online store.
Baer introduces the ALL NEW Pro Plus brake system and the Extreme Plus featuring their brand new 6P, 6 piston calipers and 14” slotted, drilled and zinc washed, 2 piece rotors for front and rear. The Extreme plus features a MONO-BLOCK caliper for the ultimate in performance.
Attractive styling at an affordable price, Baer’s new Pro Plus front and rear brake systems are sure to please the most demanding owners and impress the most critical on-lookers!
The 6P calipers were designed to employ the same pad as is OE on Corvette C5 and C6 applications. This high performance pad style is available in more compounds ranging from street use to full race than that of any other pad, including many compounds available directly from Baer!
Utilizing the same technology often only found in competition motor sport brake systems costing thousands more, Baer has created one of the most powerful brake systems for the money ever offered by Baer! With features like internal cross-over tubes, standard powder coated finishes in Red, Black or Silver, slotted, drilled and zinc washed rotors in either 13” or 14”, the NEW Pro Plus brake system is sure to look as good as it performs!
Systems contain all necessary mounting brackets and hardware, and even come with stainless steel braided hoses, except where noted. All components meet DOT specifications and are street legal in all 50 states. Ask our competition if theirs is!
While designed to fit most popular 17” or larger wheels, our 13” version will even fit some 16” wheels! To verify fit in any wheel, please download our brake template to check your wheel for clearance. Note: Baer recommends that you check any wheel at any diameter for clearance as wheel center designs also have an effect on caliper clearance.
•State of the art, leading edge technology, 6P calipers!
•Calipers use the same pads as the Corvette C5 and C6!
•The only 6 piston systems currently manufactured that have cosmetically matching 6 piston calipers front and rear where rear Pro Plus systems are offered! Note: Rear calipers are physically the same externally, but feature smaller diameter pistons for proper system balance.
•Meets full DOT specifications!
•Smooth contours and your choice of standard Red, Black or Silver powder coated calipers!
•Two piece rotors, standard with slotted, drilled and zinc washed finish in both 13” and 14” diameters!
•Thousands less than systems using comparable calipers with similar technology!
•Increased brake torque, fade resistance and improved pedal feel!
http://estore.websitepros.com/212053...+Brake+Systems
As with all our products, find a better price? Bring it to me
Old Apr 10, 2010 | 03:18 PM
99blancoss's Avatar
099blancoss
Former Vendor
These are massive rotors and calipers, they will improve your stopping abilities.
I'll post a side by side comparison in a few days. We are swapping a set onto a car right now that has the equivalent of a C5 system on it already. (Baer GT+ kit).
Our anniversary sale is coming up, all Baer systems will be 5% off
Old Apr 17, 2010 | 10:24 AM
99blancoss's Avatar
099blancoss
Former Vendor
I'm not sure swapping pads can be any easier. Two nuts and the Caliper lifts off. Takes literally 3 minutes to swap pads.
Two piece calipers can flex, the Mono block will not.
•Stiffest possible caliper design. The single most important performance element of any caliper, stiffness is the ability of the caliper to maintain its shape under all braking conditions. This optimizes the pad to rotor interface and provides the highest possible force while delivering the best “feedback” to the driver under the widest possible braking conditions. In short, Baer has it, the others don’t!
Old Jul 17, 2010 | 12:15 PM
99blancoss's Avatar
099blancoss
Former Vendor
ttt
Old Jul 17, 2010 | 07:20 PM
had2have-it's Avatar
had2have-it
Purdy, how much? are they compatible with stock master cyl? Some larger calipers require and different master cyl ratio...
Old Jul 17, 2010 | 10:03 PM
98ragtop's Avatar
98ragtop
Default Baers
HOW MUCH IS A SET FRT & RR I will be using my calipers stock 02 Z06
Old Jul 17, 2010 | 10:29 PM
99blancoss's Avatar
099blancoss
Former Vendor
stock is fine
Old Jan 4, 2011 | 10:40 AM
99blancoss's Avatar
099blancoss
Former Vendor
ttt
Old Jan 5, 2011 | 01:54 PM
charger21's Avatar
charger21
C5 of Year Finalist (track prepared) 2019
Great brake package, great price!
To Baer Brake Systems Sale
