Catalytic converter deletes
Old Apr 7, 2010 | 10:10 PM
tonyda1st's Avatar
tonyda1st
Default Catalytic converter deletes
My car has been smelling kind of strange for a while now, i took it to a mechanic that specializes on corvettes, he says is fine but don't know where the smell is coming from.
I have a feeling I may need new catalytic converters, I took it to the muffler shop they said the only way to tell if is going out is a bad smell and lack of power,
Im thinking of installing the Cat conv deletes, any idea of the benefits, pros and cons of going with deletes?
am i still going to pass the Texas State inspections and will any lights come out? is there any plugs i have to delete? anyone know?
Old Apr 8, 2010 | 03:52 AM
Rohan's Avatar
Rohan
Unless you are building a 9 second car and you are trying to squeeze and extra 3 to 5 hp out you should leave them on. Your stock cats actually flow very well and removing them will only cause you to keep setting codes on the DIC, have exhaust fumes actually come into the vehicle, and create loud occasional backfires. It's really a waste of time unless like I said, you are building a race car. And as far as passing inspection it depends on who is inspecting your vehicle and what kind of mood they are in. It's hit or miss on that.
Old Apr 8, 2010 | 06:02 AM
dieseldave56's Avatar
dieseldave56
Default Can you smell that smell.......?
Generally if you have an exhaust smell thats odd it will be from old fuel or fuel additives. If the Cat(s) are functioning , the exhaust temperture going into the Cat is lower than the temperture coming out. That's what a catalytic conveter does , burn off unburned fuel. Use a infrared temp. gun. This is standard practice.
Obvuiosly if you have performance problems (terrible acceleration/ no top end speed) or show a trouble code the Cat is a likely candidate. You have the older single 'brick' Cat design. I'm not sure if Texas required the 'pup' converters ( as California did ) to meet the LEV emissions.
If you have to meet emissions test standards, why would you want to remove the Cat(s)? There are low backpressure performance Cat conveters ( the 2002- C5 dual brick converters have slightly lower backpressure then OEM)
Old Apr 9, 2010 | 05:51 PM
tonyda1st's Avatar
tonyda1st
thanks, I'll rather keep my car stock I really don't want to mess up anything or get any codes, i was just able to clear some by replacing my tpms so, I guess the deletes are out of the question. Now I have no idea if the smell is due to the the cats or not,
Old Apr 9, 2010 | 05:53 PM
tonyda1st's Avatar
tonyda1st
ummm, someone just asked if i wanted to buy some cats from an 04, does that mean they will not fit? or give me any trouble?
To Catalytic converter deletes
