My driver seat isn't minding well these days in the '02. When I remove the ignition key to get out of the car, the seat moves back as it's supposed to, some times, but not all the time. When I get in and insert the ignition key, the seat does not move to its memory position. I've tried several times, to re-set the memory, but to no avail.
Since I don't hang-out here much, I don't know if others have encountered this problem, so please have patience...
I can't believe no one else has had this happen to their '02.
Had the same problem for months. Finally had the battery go dead on me. Charged it and it was okay for a day or two. Went dead again. Finally replaced it with a 7YR Professional from ACDelco. Problem solved. HTH
