Engine power loss/oil pressure stuck high
Old Apr 9, 2010 | 06:45 PM
Scoobi_FreeBSD's Avatar
Scoobi_FreeBSD
Default Engine power loss/oil pressure stuck high
Today I tried to start the car to drive to my local watering hole, but the car would only barely maintain idle without dying. I could rev the engine to a fairly high RPM or slowly let off the clutch, but the engine would die. It resembled my gas-powered weed wacker with the choke on, but I don't know how to correlate that with my V8. After sputtering a few yards past my driveway and trying to limp back, it finally started behaving normally with normal power. The only other thing I noticed when the anomaly was occurring was the DIC message "Service Steering Column Lock" or similar - I installed the column lock bypass when I first got the car in '05! Message went away when the car started working.
My first suspicion is the electrical system - namely, the grounds I keep putting off cleaning. I also have an oil pressure gauge stuck at 129-130 psi....related?
Old Apr 9, 2010 | 06:46 PM
lucky131969's Avatar
lucky131969
codes?
http://www.c5forum.com/ayc/dtcdic.php
Old Apr 9, 2010 | 06:51 PM
FRCTony's Avatar
FRCTony
Sounds like the fuel cut from column lock issue. If the engine runs and revs fine until you try to move, that's it.
Doesn't matter if you have a bypass. If the car thinks the column is locked...
Oil pressure is also a common issue.
Old Apr 9, 2010 | 06:58 PM
Scoobi_FreeBSD
OMG! That makes sense...thanks!
Old Apr 9, 2010 | 07:01 PM
Scoobi_FreeBSD
Originally Posted by lucky131969
Sorry, I'm at Taco Mac now, I can get 'em to ya when I get back in. I think FRCTony's response makes sense tho... I'm sure that's it.
Old Apr 9, 2010 | 07:27 PM
SKEMU's Avatar
SKEMU
The peggd oil could be the sending unit has gone bad.
Old Apr 10, 2010 | 06:42 AM
Scoobi_FreeBSD
Yeah, that's what I'm thinking too...are they pricey? I'll Google it now.
Old Apr 10, 2010 | 08:04 AM
k0ts's Avatar
k0ts
I don't understand the drive-ability issues but the pegged oil pressure is most likely the sending unit.. A relatively easy fix...
http://forums.corvetteforum.com/c5-t...sure-unit.html
To Engine power loss/oil pressure stuck high
