Engine Grounds
Old Apr 12, 2010 | 05:42 PM
lucky131969's Avatar
lucky131969
Default Engine Grounds
Removed.
Old Apr 12, 2010 | 05:50 PM
Nver2loud's Avatar
Nver2loud
What sparked this? Did too many people ask you about this already in the last week or what?
Old Apr 12, 2010 | 11:07 PM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
Good info everyone should be aware of. I have seen bad grounds cause some odd problems.
Old Sep 27, 2010 | 01:37 AM
z06 vett's Avatar
z06 vett
Default wow
just did a rebuild and had the drive line out.
low oil level with no code on the reader .no fuel at rail but pump primes(whines).i just bought the 04 service man..looks like this ground issue will fix me.
thanks,
mike
Old Sep 27, 2010 | 08:53 AM
LoneStarFRC's Avatar
LoneStarFRC
Bump for a very worthwhile post from Luck.
Grounds (or lack of) can be a real source of headaches for us guys with our plastic cars. I think too many people take them for granted until they have a problem and then wind up chasing a problem that many times is intermittent in nature. The worst kind.
Despite not having any current electrical issues (other than an apparent flaky ignition switch that will get replaced later this week), I have chosen to take the precautionary step of adding a couple extra grounds. One from the case of the alternator to ground stud at G101 and the other from the R/H cylinder head to ground stud G102. These are very easy to add and only need approx 14" of wire with a ring terminal on each end, 5/16" on one end and 3/8" on the other. An "Ounce of prevention" kind of thing.
Old Sep 28, 2010 | 12:51 AM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
That's what fixed my column lock problem. I ran a ground wire from G202 to the negative side of the battery cable.
Old Sep 30, 2010 | 05:34 PM
z06 vett's Avatar
z06 vett
Default sorted
fired up today,
ran a ground from the rail to the frame ,bingo!!
mike
Old Sep 30, 2010 | 07:25 PM
lucky131969
Originally Posted by z06 vett
fired up today,
mike
Rail?
Old Sep 30, 2010 | 07:50 PM
TurboBerserker's Avatar
TurboBerserker
Originally Posted by lucky131969
Rail?
You know, where the big train wheels are.
Good post Lucky. Some of those grounds can be a real bastard to find without shop manual pics.
Old Nov 12, 2011 | 08:16 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Hell YES!! You would be amazed at the number of people that either leave G-106 OFF or Connect it to the SOLENOID +12 Terminal. We are continuously providing assistance with ground issues and the ones Lucky has highlighted are frequently high on the list!
The Engine grounds are LOW, out of sight and difficult to get to
People often have no idea that there there or even important.
OUTSTANDING Job Lucky!!!!!!
Bill
Old Nov 12, 2011 | 11:03 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Nver2loud
This post was posted earlier today!!!
http://forums.corvetteforum.com/c5-t...post1579202653
See.... It happens ALL THE TIME!
Bill
Old Nov 22, 2011 | 08:49 PM
WKMCD's Avatar
WKMCD
Just came in from the garage after finding my G105 loose while chasing an electrical problem. That may be all it is. I'll know tomorrow.
Old Nov 22, 2011 | 08:55 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Hope the FIX was as easy as that!
Bill
Old Nov 22, 2011 | 09:01 PM
WKMCD's Avatar
WKMCD
Bill
I've already gone through the ground blocks on the front of the frame by the hood hinges. When I went to put the battery back in I noticed the brass adapter bolt I have so I can hook up the amps is stripped and wouldn't tighten up. I didn't notice it loose when I took it out but it's highly possible it was. I'll get it back together tomorrow and see what happens. If that doesn't do it....it's into the driver's door accordian.
Thanks to both Bill and Lucky!
Old Nov 27, 2011 | 07:11 AM
fendermender's Avatar
fendermender
Great info. I'll be using this when the engine goes back in. I have a bad habit of missing connectors. And this thing has a ton of em!!
Old Nov 27, 2011 | 09:42 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The most common ground mistakes are G105 G106 and G107. There easy to forget about. Quite frequently people often put the wire for ground G106 on the STARTER SOLENOID!!!
You will be amazed the FUN that causes!
Old Mar 23, 2012 | 01:15 AM
Zeus-of-Boost's Avatar
Zeus-of-Boost
why isnt this a sticky ???????????????? or in the stickys. had to GOOGLE to find it after a day of looking.
To Engine Grounds
Old Mar 23, 2012 | 10:48 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Excellent info. and wiring diagrams lucky!
Bill Curlee has also been preaching the importance of good electrical grounds for many years.
Ground connections can be so easily overlooked when you're anxious to get that new engine bolted in and fired up.
Old Mar 23, 2012 | 11:13 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Something else to consider or should I say watch out for is, Make sure that you don't attach ground wire G-106 to the starter solenoid by mistake. It has an eyelet on the wire that fits on the starter lug just fine.
Mike and I have seen this issue too many times not to warn people in advance of the mistake.
Yep, All the engine grounds are very important and frequently overlooked or discarded as insignificant wires.
Far from the truth!
BC
Old Mar 23, 2012 | 12:19 PM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
Thats like the extra parts box...
