A few months ago I had some LG Pro Headers installed and now my Check Engine light keeps coming on. The diagnostic reading says that it's a slow response on Bank 2 Sensor 1 (O2 Sensor?). I've replaced the sensor 4 times already and still keep getting the light. Sometimes I can go a month or two with no light and sometimes it comes on right away.
Any advice on why this might be happening would be greatly appreciated. Thank you in advance.
So a P0153 then? This seems to be common on LG headers....I'd like to know why. To cover the bases, make sure you inspect the wiring for heat damage.
But he said Bank 2, sensor 1. Aren't the rear 02's Bank 2 sensors 1 & 2 ?
No, drivers side is bank 1 with front sensor being sensor 1 and rear sensor sensor 2. Passenger side is bank 2 with front sensor being sensor 1 and rear sensor being sensor 2.
I couldn't find a decent diagram in the manual but if you go to the section for replacing the sensors you can clearly see which is which.
Do LG's call for using a rear sensor in the front position?
Yes, they even give you adapters with the headers for that purpose.
This might seem very stupid but I did it and from talking to a few people, it's a common mistake: make sure that the O2 sensors are plugged in the correct sides. I know that they are faced in a way that would make you think you plug them in crossed but you do not. Plug the O2 sensor in onto the same side.
I had the exact same problem. Talk about frustrating...
The problem, as I was explained from a very competent Corvette-only specialist (who fixed my problem) is that the code (PO0153, I think it was...also, PO0133 for the other side) is a slow heat response time from the O2 sensor. This happens because the O2 sensor is now located further away from the engine. Stock exhaust has the O2 very close to the head/exhaust port. With headers, especially long-tube headers, the O2 sensor is relocated to downstream of the collector. Apparently, this means it doesn't get as hot as it does next to the engine.
IF you can find someone to rework the program to ignore those two codes, it goes away. The other option is to have a tap welded on to your header tube next to the exhaust port, but then if you have a problem in one of the other cylinders, you won't know it.
...or, you could just use the other type of O2 sensor and an adapter. (Probably cheaper too.)
Do the codes affect the performance of the car by having it run richer/leaner? If so, does programming them out fix any such problems?
The codes themselves do not affect the performance; however, the behavior of the sensor #1 positions for both banks certainly will. Who installed the headers, and did the move the rear O2's to the front?
IMO, you certainly want the front O2's reporting codes.
Agreed, you definitely want the O2 sensors reporting codes...BUT, by telling the computer to ignore ONLY trouble codes PO0133 and PO0153, the sensors still function perfectly fine, but the computer just ignores the "slow heat response" code. It does not affect the performance of the sensor at all.
But a slow response can be a wiring problem as well. A P0153 code is reporting the performance, not necessarily the slow response as result of a poor(or non-functioning) heater circuit.
Getting ready to install these as well, did the OP ever confirm the rears are moved to the front or did he install the fronts back in their original position (although I don't think they will reach)?
Nope. LG recommends moving the rears to the front(using adapters), and tuning out the codes for the rears.
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I suffer the same problem with Dynatechs. I moved the rears to the front with LG adapters supposedly because they heat up faster. Or get hotter. Anyways when it does happen I just reset the codes from the DIC. I've gotten so good at it I do it flying down the hiway. I used to pull over and shut off the car to reset the codes but that grew old fast.
