Car Won't Start
Old Apr 17, 2010 | 03:43 PM
topkart43's Avatar
topkart43
Default Car Won't Start
I have an 02 Z06 and it won't start. It has a brand new battery on it and when I turn the car to on everything comes on but when I turn the key all the way over to start the engine everything shuts off. I don't know if I have a short somewhere or what. The car doesn't make a ticking noise from the starter or anything. Anybody ever had this problem and a solution?
Old Apr 17, 2010 | 03:50 PM
lucky131969's Avatar
lucky131969
Check your battery cables for security. Pull codes...
http://www.c5forum.com/ayc/dtcdic.php
Old Apr 17, 2010 | 03:59 PM
VinnyT's Avatar
VinnyT
Do you hear the seat beat chime or the fuel pump pre-load? As lucky said check the cables and codes. Also, try cleaning the security chip contacts on the key with a pencil eraser.
Old Apr 17, 2010 | 04:21 PM
topkart43's Avatar
topkart43
Yes I hear the chime..The car isn't showing any codes either
Old Apr 17, 2010 | 04:23 PM
lucky131969
To be clear, you used the above link, and there are no codes checking through the DIC.
Old Apr 17, 2010 | 05:04 PM
topkart43's Avatar
topkart43
The only codes that came up were for my traction control system, which i need to fix. Other than that nothing else. I do hear the fuel pump come on too.
Old Apr 17, 2010 | 05:05 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When you turn the key to START/CRANK,,,the ignition switch turns OFF a lot of things. It reduces loads on the battery and protects delicate electrical systems from excessive voltage variations. Thats what your seeing. Have some one attempt to start the engine and you, whack the starter with a plastic mallet.
I bet it will start.
On another note,,,as Lucky stated,,,battery cable integrity is CRITICAL. Each terminal must be clean and torqued to 11 ft/lbs. (97-03 C5's)
BC
Old Apr 17, 2010 | 05:18 PM
lucky131969
Old Apr 17, 2010 | 06:45 PM
99mikeb's Avatar
99mikeb
Default starter solenoid
HAD THE SAME PROBLEM LAST WEEK,AND FOUND OUT THE STARTER SOLENOID failed.It's not that tough to change yourself,if you have some basic mechanical skill.Check DIY threads on installing a starter.Cost for starter $220.00.
Old Apr 17, 2010 | 07:18 PM
clif's Avatar
clif
St. Jude Donor '09-'10
I had the same issue a couple of months ago. My issue turned out to be a broken shift cable, that kept the tranny in a gear that was not Park. ( I have an A4). After toubleshooting with the help of a forum member, we found the issue.
Old Apr 17, 2010 | 08:10 PM
lucky131969
good point clif...I remember that ...except the OP has a ZO6....so it's a manual.
Old Apr 17, 2010 | 10:26 PM
daleweible's Avatar
daleweible
I guess we all own c-5's I had the same problem in December. I checked everything I could, because I could not test both sides of the starter fuse, I pulled it, showed very little corrosion but when I put it back in problem resolved. Generally batteries and starters provide so warning prior to failure, not always but probably 99% of the time. Check cheap things first.
Old Apr 18, 2010 | 10:04 PM
topkart43's Avatar
topkart43
I pulled the starter out and took it a local autoparts store to have it tested. It worked but sparked really bad as it was running. The clerk at the store said that would cause it not to turn over, along with the corrosion on the connectors. Could this be the cause of the car not starting?
Old Apr 18, 2010 | 10:52 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
SPARKED?? The damn things is sealed. Where was it sparking?
The Parts store is there to sell parts. Unless it DIDNT WORK,,,its most likely good. Dont let them bully you into buying parts you dont need.
If your at ANY DOUBT,,,,buy a NEW SOLENOID, install it and reinstall the starter.
Bet ya it works fine!
BC
Old Apr 18, 2010 | 11:21 PM
topkart43's Avatar
topkart43
They put it on a tester and as the guy pushed the button to turn the starter over a spark would come out of the ground connector I believe. The clerk pulled over two other guys and they tested it again and said that the spark was jumping between connectors. They suggested since there was alot of errosion on it that i could prolly clean up the connectors and id be in good shape, but with 135,000 miles im wondering since i have everything apart that i should just buy another one. The guy also said since erosion comes heat and thats why the car wouldn't turn over.
Old Apr 18, 2010 | 11:44 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Unless the clamp on connections are TIGHT,,,,yea,,,it may spark when it draws 300 amps. Clean up the connections and make sure that you have a good connection. The main wear part of a starter on a C5, is the solenoid. if its bad,,,,the car will NOT start.
BC
Old Apr 19, 2010 | 12:00 AM
topkart43's Avatar
topkart43
So if the starter turned on the tester does that mean it should start my car?
To Car Won't Start
Old Apr 19, 2010 | 12:03 AM
1999_TRC's Avatar
1999_TRC
I hope before pulling the starter, you at least checked for 12 volts to the purple wire when trying to start the car (clutch pedal in, key to start).
Old Apr 19, 2010 | 12:06 AM
topkart43's Avatar
topkart43
No I didn't. I had a buddy who also own a 02 z06 and he said his did the same thing and it ended up being the starter. What purple wire would I test?
Old Apr 19, 2010 | 01:33 AM
topkart43's Avatar
topkart43
Also two ago when i went to start the car it just make a single click noise and wouldmt turn over. Then it finally turned over and ran fine for a day then again wouldnt start, and once again finally turned over. But the other day when i drove home and went to leave nothing, no click or anything. I have no problem turning my key in the ignition.
