3.73 Install
Old Mar 14, 2002 | 10:44 PM
ph3n0m73's Avatar
ph3n0m73
Default 3.73 Install
Thinking about changing out the 3.42 with the 3.73 ring and pinion. Was wondering...
1. What do you think the install would cost.
2. If I did it myself, how long of a job it would be.
2.a. Do I really want to do this myself?
3. Would it be worth it?
4. Do I need to reprogram?
Any and all input appreciated.
Thanks.
Old Mar 14, 2002 | 10:59 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: 3.73 Install (ph3n0m73)
My Chevy dealer quoted me $368 for labor.
it took me 10 hours to do mine; but I was anti-hurry.
it isn't all that "technical"; but labor intensive. Also you need a second set of muscles[/i]
certainly; but traction issues may be a problem (lack of traction :) )
with a MN6, no (at least that is what I've read on the forum).
visit this web page for the procedure:
mikemercury.home.att.net/342.htm
Old Mar 17, 2002 | 08:31 PM
ph3n0m73's Avatar
ph3n0m73
Default Re: 3.73 Install (Mike Mercury)
Thanks for the info, Mike.
Great link. Makes me think I could possibly accomplish this.
:D
Old Mar 17, 2002 | 08:45 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I will spend the money! $420
Old Mar 17, 2002 | 09:45 PM
Brutus0725's Avatar
Brutus0725
Default Re: 3.73 Install (wallstAL)
Old Mar 17, 2002 | 10:01 PM
akw408's Avatar
akw408
You don't need to reprogram, but your speedometer will be off unless you do something like HPP3 or some reprogramming.
99 C5 M6
Old Mar 17, 2002 | 10:10 PM
bruce1's Avatar
bruce1
Default Re: 3.73 Install (akw408)
99 C5 M6
Shift points will be off...only if you have an A4 that is....... you must re-program.... if you want it to shift right using the A4........ :chevy
[Modified by bruce1, 6:11 PM 3/17/2002]
To 3.73 Install
