Crank pulley replacement?
Old Apr 18, 2010 | 06:13 PM
PhilsZ51's Avatar
PhilsZ51
Default Crank pulley replacement?
I was removing my crank pulley and damaged one of the grooves. Where is a good place to get a stock size replacement? I don't want to go smaller or bigger because I am sure it will effect the boost level on my SC. Thanks for the help.
Old Apr 18, 2010 | 06:21 PM
UniqueDoug's Avatar
UniqueDoug
Power Bond is highly recommended and they have a stock size I believe... Call Texas Speed, they had a good price on my 25% UD...
Old Apr 18, 2010 | 08:34 PM
corvette8189's Avatar
corvette8189
ill sell you my stock one cheap, pm me if you want
Old Apr 19, 2010 | 06:08 PM
road dog's Avatar
road dog
fluidapner my choice its also power bonded self balancing with engine ware
Old Apr 20, 2010 | 06:02 PM
lionelhutz's Avatar
lionelhutz
I'd highly recommend you get an aftermarket unit and put a pin into the crank to work like the key would. Then, you won't spin it on the crank snout in the future.
Peter
To Crank pulley replacement?
