Lowering question?
Old Mar 15, 2002 | 12:43 AM
RG in Dallas's Avatar
RG in Dallas
Elite Member
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Lowering question? (Buckmaster)
From "GMan's" post in tech tips on the front lowering:
Front:
1. Make sure the car
is in gear to prevent it from rolling.
2. Raise the car with
the jack positioned in the center of the front cross member.
3. Place the two jack
stands under the cross member, and SLOWLY lower the car onto them.
4. Remove the front
wheels. It may be necessary to slightly loosen the lug nuts before the
wheels are completely off the ground.
5. Find the front
leaf spring, and with a 10mm wrench or socket, turn the bolt as if you
were loosening it (It is reverse threaded so you are actually tightening
it).
6. Turn the bolt until
there is no longer a gap between the bushing and the bolt. Measure the
exposed threads to insure the other side is done the same.
7. Put the wheels
back on and lower the car. NOTE- It may be necessary to place a board
under the tires so you will be able to remove the floor jack once the
car is lowered.
:cheers:
RG
Old Mar 15, 2002 | 12:44 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In V Veteran
you want to back them out. The front bolt will be raised up closer to the shock and the back bolt will be loosed. :seeya
Old Mar 15, 2002 | 08:07 AM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
Slam that badboy!!!!!! :D
Old Mar 15, 2002 | 08:38 AM
G Man's Avatar
G Man
Chris, RG thanks :cheers: tomorrows project :D
Let me know if you have any questions.
To Lowering question?
