C5 starters
Old Apr 22, 2010 | 01:15 PM
hobbesnmina2001's Avatar
hobbesnmina2001
St. Jude Donor '10-'11-'12,'14
Default C5 starters
Are C5's hard on starters?
Are bad starters or sticking solenoids common on C5's and Z06's.
The starter does not have a heat shield and with everything being so tight it looks like they get heat retention.
Old Apr 22, 2010 | 01:22 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The starter its self is almost bullet proof. The solenoid on the other hand fails quite often. They will cause a fail to crank. There $60 to replace.
trk982003's Avatar
trk982003
I cant answer about how common it is, but my starter solenoid failed. Its not serviceable, so installed a reman starter and starter heat wrap from Jegs i think. No problems now. I have a few customers with c5's and havent had anytroble with theirs.
Old Apr 22, 2010 | 01:59 PM
hobbesnmina2001
"I cant answer about how common it is, but my starter solenoid failed. Its not serviceable, so installed a reman starter and starter heat wrap from Jegs i think. No problems now. I have a few customers with c5's and havent had anytroble with theirs. "
Thanks for the replies. My Z only has 10,000 miles and it's looking like its the culprit and yes it fails to crank. No DTC's, no resistance on the POS battery wire, some on the neg battery wire. I hooked up an extra ground to test it and the OHM went to zero, clicks but no crank. I took a long screw driver and went directly from pos starter post to solenoid and it clicks but not crank over.
Old Apr 24, 2010 | 08:39 AM
hobbesnmina2001
OK, got my answer! The problem was a craked nose on the starter!
At first I had a suspicion about it but kept thinking it only has 10,000 miles!
Yesterday I dropped the exhaust and as soon as I got the starter out? A crack around the nose!
Well that answered why my other battery dropped in charge super fast, and the wires starter where getting quite warm like there was a short...because it was...the armature and body!
I asked my parts guy if he saw that on LS starters as I thought it was rather unusal and he said yes he has seen it before!
Along the way I learned a lot about pricing on starters and solenoids on LS motors!
Old Apr 24, 2010 | 09:00 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WOW! Thats a FIRST for me! I know that they will destroy them selves if the engine hydrolocks and you try to crank it. Never seen one just crack for no reason.
Bill
Old Apr 24, 2010 | 09:11 PM
hobbesnmina2001
Bill
Hi Bill, actually I was worried about that myself but I lucked out.
It's a long story, but the short version I was installing some new 42# (50# at Vette pressure) injectors because I wanted to tune it for E85. I use HP Tuners and due to my mistake I wrongly downloaded a slightly different tune that still had the stock injectors written. Of course on start up it sent a bunch of fuel and as the engine started it stalled. I still was not aware of the mistake and I hit the starter again where it just started to turn then stopped! Then realizing something was not right and checking the tune I found my mistake. I pulled the plugs and got a little fuel from #2, #7, and #8. The engine started to turn without the plugs and then stopped.
Like I said what initially was throwing me off was that the car is low mileage 10,700 and I was not aware about the starter noses breaking under those conditions.
I lucked out because everything seems fine, no codes, oil pressure good, engine pulls smooth!
We took a nice ride tonight and the little LS6 was humming along real sweet!
Old Apr 25, 2010 | 08:06 AM
trk982003's Avatar
trk982003
Excellent man, glad it wasn't worse. I havent seen a gen3 starter go in that manner in a 'vette or truck alike. Sounds like you found the problem though. Good luck glad you got 'er runnin!
Old Apr 25, 2010 | 09:57 AM
hobbesnmina2001
Thanks, happy it worked too! I was thinking Oh boy you did it now!
An interesting side note is that we got the car in November with only 8272 miles and the mpg has been 26-27 on the highway which IMO was good, much better then the old 426 Hemi Challenger, or SS396 375 HP Camaro!
Anyways there was no evident missfires, or dtc's but our local bank officer and her husband got better mpg on the highway with their 02 Z06 on cruise which is how I drive. When I took the plugs out # 7 was not totally bad but not as good as the others. I just replaced the wires and when I put the plugs back in I put that one in # 2 (easier to get to ) and yesterday I had a missfire show up on #2. I then put a new Denso iridium plug in #2 and the engine is much better, no missfires and on the way to work the mpg climbs faster and seems better then before on the highway! My combined mpg this morning was 28 mpg over 32 miles to work, which I never had before, more like 25-27!
Old Apr 25, 2010 | 10:23 AM
postwhore's Avatar
postwhore
Old Apr 25, 2010 | 11:09 AM
hobbesnmina2001
Originally Posted by postwhore
You replace the solenoid, it is not taken apart and repaired. The auto parts stores don't carry solenoids anymore, but a stater/generator rebuilder does. I found one locally for less then $30.
Old Apr 25, 2010 | 02:55 PM
postwhore's Avatar
postwhore
that is actually what I thought
but the one guy said it's not serviceable which did not make any sense
Old Apr 25, 2010 | 07:17 PM
hobbesnmina2001
Yes, he means the solenoid tself is not serviceable, you replace the solenoid with another one. Before I got home I picked a new one up, then I found the crack so I just kept it as a spare.
To C5 starters
