Water pumps
Old Apr 23, 2010 | 09:06 PM
AJ Powers's Avatar
AJ Powers
Default Water pumps
I'm researching water pumps and one company advertises:
* Increase pump pressure up to 300 percent
* Eliminate steam pockets trapped inside the engine block
* Reduce engine temperature by 15-30 degrees
I realize the radiator cap maintains overall system pressure, but would/could the increase pump pressure cause any problems?
Old Apr 23, 2010 | 09:13 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Increased pressure means more HP to drive the pump. This wp was talked about before. Don't waste your money. Just install the stock pump and call it good. Nothing more needed.
