Not Sure....I need help
Old Apr 26, 2010 | 11:39 AM
dsolis12's Avatar
dsolis12
Cruising
Default Not Sure....I need help
I have a 1999 that the oil pressure reads max 80 psi, and the computer says 130psi. After research some say a PCV and some say oil pressure sensor. Has anyone been down this road before?
Old Apr 26, 2010 | 11:58 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
It's the oil pressure sensor in the rear, behind the intake manifold. It's a (4) beer job.
Old Apr 26, 2010 | 12:27 PM
dsolis12's Avatar
dsolis12
Cruising
Thanks, does anyone know what part would work best? There are a few different makers, AC delco, BWD.........they actually look different too.
Old Apr 26, 2010 | 12:44 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
check the top of this page for info and options...
Old Apr 26, 2010 | 03:09 PM
Oldvetter's Avatar
Oldvetter
The way to check if it is the oil sensor (or a short in the wires) is to turn the ignition on with the engine off, if any oil pressure registers, it is the sensor or a short in the wires. There should be NO oil pressure with the engine not running.
Good luck, make sure you use proper torque and clean all the oil off of the connector.
Old Apr 26, 2010 | 10:35 PM
dsolis12's Avatar
dsolis12
Cruising
It worked!!!!!! I went to O'reilly.... they had the $38.00 sensor in stock. And now I got your standard 45 psi on the gauge and the computer. Awesome. Thanks for the info.
Old Apr 26, 2010 | 11:33 PM
SSWEET's Avatar
SSWEET
So how bad was the job....
Old Apr 27, 2010 | 09:27 AM
dsolis12's Avatar
dsolis12
Cruising
Well I am pretty much a perfectionist.........by no means am I a mechanic. It would have taken about an hour. But when I got in there I saw some emission hoses that were rotting, so I stopped and went to the auto store to get some parts. Then the day was so nice..........I bought some brake cleaner and cleaned out all the intake holes that had crap all in them. All in all it took about three hours, but I was lolli-gaggin the whole way.
To Not Sure....I need help
