Newer computer in a 97 Vette help
Old Apr 28, 2010 | 10:19 PM
forcefed97c5's Avatar
forcefed97c5
Default Newer computer in a 97 Vette help
looking for info on putting a later model ecu in a 97 vette. Is it possible? What does it take? What all will I need to change? need some expert advice here or at least some one who has done it.
I am thinking 98 99 2000 ecu let me know what you think.
Thanks in advance.
Trent
Old Apr 28, 2010 | 11:32 PM
4DRUSH's Avatar
4DRUSH
http://forums.corvetteforum.com/c5-t...-corvette.html
Old Apr 29, 2010 | 07:48 AM
minitech's Avatar
minitech
Thanks in advance.
Trent
What is the ultimate goal of doing it? If it is so you can adjust some settings (I know the 97 is limited for some things) consider buying a dyno tune with the money instead. With the software they have they might be able to meet or exceed what you want to do for less money and without all the wire cutting.
Old Apr 29, 2010 | 10:02 AM
forcefed97c5
I turbocharged my car and I am at the limits of my maf.. Newer ecu will let me eliminate maf and go with a 2 or 3 bar map sensor.
Old Apr 29, 2010 | 12:01 PM
corvettebob1's Avatar
corvettebob1
" am thinking 98 99 2000 ecu let me know what you think."
98 will be the same as your 97 PCM.
The later model PCM will allow way more resolution for tuning.
I just had mine changed to a 2002 by EFI Alchemy and even though we're sorting through some issues now I can see a great improvement over all.
To Newer computer in a 97 Vette help
