whats up people? need some help got a little confused with the O2 sensors because when i took them off the stock setup they ran from the left pipe to the wire harness on the right side of the car and the right pipe to the left harness. now when im putting them in the new headers do i do the same thing (Cross them) or go from left to left, right to right?
However, on the LG's the rears are usually left out and moved to the front where an adapter is used so the square plug on the rear sensor can be used on the front flat blade connection. The rear is either plugged or a sim is used. What is confusing on the LG's is the angle the fronts are mounted make it appear they should be crossed but they shouldn't.
