Overheating
Old Mar 16, 2002 | 08:06 AM
tds69tx's Avatar
tds69tx
Default Overheating
My C5 runs at about 192 degrees out on the open road but I noticed when leaving the engine at idle for any length of time, it will climb to about 226 degrees. This is w/ or w/o the AC on. I have yet to hear the fans running. Could it be a relay switch for the fans? I have flushed the radiator and replenished w/ new fluid. Any thoughts?
Thanks---TD :cheers:
Old Mar 16, 2002 | 08:39 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Overheating (tds69tx)
This condition is normal, the fans dont come on till 230 deg... if you want the fans to come on early you will need to turn on the AC to high and push the recirculate button on the dash (if you have the electronic version) to make the system go to high. The fans should go on and the engine temps will drop quickly.
vetterdstr :cheers:
Old Mar 16, 2002 | 09:26 AM
oceanaire's Avatar
oceanaire
You could also get a lower temp thermostat and a Vinci fan motor controller that will tell the fans to come on earlier. I live in S. FL, and my temps hardly ever go over 212 with this setup. Eric.
Old Mar 16, 2002 | 10:13 AM
Scruffy's Avatar
Scruffy
225* F idling in traffic is normal. You won't feel or hear the fans as they are quiet and well balanced.
Old Mar 16, 2002 | 12:50 PM
speeder75's Avatar
speeder75
Default Re: Overheating (Scruffy)
i have the same problem but the temperature over here reaches 120f or even more
Old Mar 16, 2002 | 01:17 PM
tds69tx's Avatar
tds69tx
Default Re: Overheating (vetterdstr)
So should I assume this is nothing to worry about? :confused:
Old Mar 16, 2002 | 02:23 PM
carpe dm's Avatar
carpe dm
Sounds OK to me. :yesnod: :)
Old Mar 17, 2002 | 04:25 PM
ersatz928's Avatar
ersatz928
Your temps are normal. The adjustable fan controller, typically sold for $129 is availible from Pep Boys Auto Stores for $39, sold under the OEM manufacturers name : Hayden. That will help your idling temps in stop and go traffic.
To Overheating
