Loud Rear Driver-side wheel
Old Apr 30, 2010 | 11:56 AM
jerry hooker's Avatar
jerry hooker
6th Gear
Default Loud Rear Driver-side wheel
I get a noise from the wheel just behind my driver's seat on my 2001 CV convertible.
My local corvette shop says the wheel bearing is fine.
The sound is exactly like a loud tire tread - but I just purchased a new set of Bridge-stone Perensia's. Sound is still there and just as loud as before.
Does anyone have any suggestions on how to narrow the search down?
JH
Old May 1, 2010 | 06:32 AM
double-oh-coupe's Avatar
double-oh-coupe
When you put the car into a turn - like an on- or off-ramp from the freeway - does the noise go away or change? I've had bvearings go out, and when I did this I could hear the noise change as I loaded the bearing differently. Just an idea ...
Old May 7, 2010 | 06:42 PM
Paris Hilton's Dog's Avatar
Paris Hilton's Dog
I think I have a similar noise. 2000 Hardtop with about 63,000 miles. Here's what I've noticed:
The frequency of the noise is proportional to road speed.
It's most noticeable around 65-80 mph.
I can engage and disengage the clutch and the noise doesn't change.
Going around a curve doesn't change the noise.
It seems like a tire issue but I'm not sure; I have Goodyear GSD3 tires with maybe 20,000 miles on them. My plan is to live with it until I get new tires and then see if anything changes.
Old May 7, 2010 | 08:05 PM
Johnny Hardcore's Avatar
Johnny Hardcore
I was getting a similar noise from the a$$ end of my vette and found the bearings were in fact shot. Replaced them and she is perfect once again.
Old May 8, 2010 | 07:32 AM
jerry hooker
6th Gear
Default Could it be a slightly out of line rear tire?
Thank you for you responses! I would like to hear from more owner/mechanics also.
Could it be a slightly out of line rear tire? I haven't noticed excessive tread wear on that tire.
But! I have never had a bad u-joint and have no experience with what they sound like when going bad.
Anyone got any experience at this noise?
Old May 31, 2010 | 05:46 PM
Paris Hilton's Dog
Well I said that I would wait until I got new tires to see if the noise would go away, but I became impatient and decided to change my rear wheel bearings now.
Bad idea.
The result is that nothing changed, the noise is still exactly the same. I knew the chances of success were very slim as soon as I got the first original bearing out. It felt nice and smooth and solid. Perfect bearing. I went ahead and installed the new bearings anyway (I used the Timken 512153 parts from Rock Auto), and also adjusted my parking brakes while I was at it. And installed Hawk HPS pads on all 4 wheels which replaced the AC Delco Durastops that I put in a while ago.
So the parking brake is really nice, the pads seem good, but I just replaced 2 good bearings for no reason.
As far as I can tell, the noise seems to be a "once per wheel rev" frequency, so maybe it really is a tire problem. On the other hand, the final drive assembly also turns at once per rev, so maybe it's a diff carrier bearing or worse yet the ring/pinion mesh is getting noisy. But it definitely wasn't the rear wheel bearings. Is it possible for a CV joint to make this sound? Doesn't seem like it but I could be wrong. In fact I was wrong just this past weekend, haha. If anyone has further info, please let us know.
To Loud Rear Driver-side wheel
