for those running TR55s...
Old Mar 16, 2002 | 01:26 PM
RogueC5's Avatar
RogueC5
Default for those running TR55s...
Just stopped by Pep Boys to see if they carried NGK TR55 copper plugs (I know - I should be watching the race) and not only had the guy at the counter never heard of the TR55 plug, he said replacing the platinum plug would negatively impact the "late model vette's" computer. I told him I'd never heard of that and he said "check it out". So I am asking the experts. Any merit to this? Thanks.
Old Mar 16, 2002 | 02:13 PM
carpe dm's Avatar
carpe dm
Default Re: for those running TR55s... (RogueC5)
There are MANY folks running TR55s, seemingly without problem. I think he meant well, and was being helpful; however, he was off base on this one. I am about to switch to them myself. Good luck. :)
Old Mar 16, 2002 | 02:21 PM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
I'm running the TR55's in my FRC....no problems to report :cheers:
Old Mar 16, 2002 | 02:26 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
I had trouble locating TR55's as well. None of the mainstream auto retailers will sell you a plug that their book does not call out! I finally found them at a little run-down parts store for $1.40 each! But the counter guy was a Corvette racing guy and he knew exactly why I wanted them.
What we need to know is what make/model calls for TR55's in their book! Then we can go in and say "I need a set of plugs for my 74 Pinto" and they won't try to sell you $10 platinum plugs!
Old Mar 16, 2002 | 02:48 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Default Re: for those running TR55s... (SDVette)
No problems here!
what do you expect from pep boys! YOU probably know more about cars than the guy behind the counter!:rolleyes:
I found the TR55's at my local NAPA auto parts store. :cheers:
what race?
[Modified by RPOZ4Z, 1:50 PM 3/16/2002]
Old Mar 16, 2002 | 03:59 PM
JerryL's Avatar
JerryL
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: for those running TR55s... (Buckmaster)
He's wrong but I'm not sure why you want to switch anyway. Cartek recommended the TR55s for my engine but that's after significant mods.
Old Mar 16, 2002 | 04:41 PM
Don Baldwin's Avatar
Don Baldwin
Default Re: for those running TR55s... (JerryL)
I use the TR55s with no problems. I purchased them at Advanced Auto Parts Store.
Old Mar 16, 2002 | 04:54 PM
2 Slow's Avatar
2 Slow
I have ran those plugs for about 1 year with no problems.
Old Mar 16, 2002 | 05:39 PM
MelloYellow's Avatar
MelloYellow
Default Re: for those running TR55s... (2 Slow)
Everyone uses these.
Old Mar 16, 2002 | 06:03 PM
FRISKY's Avatar
FRISKY
What gap?
Old Mar 16, 2002 | 06:06 PM
MelloYellow
Default Re: for those running TR55s... (FRISKY)
The 55's come at .055 I believe. Most run them there.
There is a TR5 at .050 I believe, but not 100% whether it's exactly the same plug. I think the factory used some TR5's once upon a time.
Old Mar 16, 2002 | 06:11 PM
Lone Ranger's Avatar
Lone Ranger
I tried TR55 coppers in my '95 and it idled rougher and didn't run as well as expected. Two well regarded local 'Vette mechanics told me to only use either AC Delco 41-906's (the orig equip platinum plug), or AC Delco Rapidfire platinums (Rapidfire #3 is the cross referenced one for my LT1).
I pulled the NGK's and put in a new set of stocker AC delco 41-906's and it ran really well, noticeably better than with the NGK's. But I used copper based anti-seize compound on the AC delco plugs whereas I had used a generic non-metallic based anti seize on the NGK's, don't know if that had anything to do with it but copper based anti-seize is supposed to be best for a good ground connection to the head.
It might be interesting to see if the guys having good results with NGK's are using the stock plug wires or hotter aftermarket wires. Might have to do with how the plugs work in harmony with the particular type/resistance rating of the plug wires...
Old Mar 16, 2002 | 06:22 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: for those running TR55s... (95_C4_convertible)
One thing I noticed after installing the TR-55, my dyno curve became very smooth, before it was kind of jagged! Maybe I had a bad Delco plug.
Old Mar 16, 2002 | 06:25 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: for those running TR55s... (wallstAL)
TR-55's here with no problems.
Old Mar 16, 2002 | 07:50 PM
J_Johnson's Avatar
J_Johnson
Cruising
Running NGK's now. They reduced my detonation problem significantly. No problems at all. :chevy :chevy :chevy
Old Mar 16, 2002 | 09:45 PM
99 Corvette's Avatar
99 Corvette
What gap?
.055 should work good. I measured mine and the came at .057. so I closed them down a little since I've added roughly 70hp. If you want some help from someone who has done it give me a call. As for the TR55s causing problems I don't have any problems. They have been in for a couple thousand miles and the only thing I've noticed was a smoother idle and maybe a very slight increase in hp but I imagine that is only because I had 36K miles on the stock ones and they needed replaced :cheers:
Jerry
Old Mar 17, 2002 | 01:34 AM
DraftMe's Avatar
DraftMe
Default Re: for those running TR55s... (99 Corvette)
Hard to find an honest and knowledgeable parts man. But if you ever need one, email me. I know a darn good one. He is awesome! :yesnod: :lol:
Old Mar 17, 2002 | 03:49 PM
99 Corvette
Default Re: for those running TR55s... (J-C-5)
I would have to agree with that. Jimmy is the man when it comes to getting parts :smash:
Jerry
Old Mar 17, 2002 | 04:18 PM
YO-EL's Avatar
YO-EL
No problems here.
To for those running TR55s...
