When l swapped out my stock exhaust for a Ti exhaust l went to a top
performance shop to have it done right the first time.
Anyway after l drove it home l just put it away and one week later l took it out with my wife for a nice ride.
Bottom line we started hearing all kind of noises from underneath my car but couldn't figure it out so l drove it home and jumped under the car.
What l saw was in order to swap out the Ti exhaust the mechanic loosened the rear sway bar or removed it. But after putting on the Ti exhaust he never tightned the 4 nuts holding the sway bar and causing one to come off completely.
When l called the performance shop this morning and explained what happened he said he was sorry and that l should bring it over and he will fix it.
My question being that l saw the loose nuts, l decided to make them tighter, is this ok l do not own a torque wrench.
And being that one nut is missing whould l be better off picking one up at a dealer? I want it to look like it came from the factory if possible.
There are 2 bolts threaded into the crossmember and 2 through bolts with nuts. The through bolts with nuts just happen to hold the rear lower A-arm bushings in place. I don't see it's being very safe to drive the car with no nut on one of those bolts.
Tighening them so they are snug with a hand wrench should not be a problem. Don't throw all your weight into them though.
Torque rates are usually so you don't overtighten and break the bolts. Depending on the length of wrench/rachet you are using, you can easily put over 100lbs on a 15" breaker bar. Using an open end wrench, crank them wrist tight (don't put your arms into it) If you could tighten them up 'snug' using just your wrist, you will have them tight enough to get you down the street and ask any local tire/repair shop to check the torque for you, or buy a torque wrench from any local auto parts store/sears etc. Cheaper ones are $40, you'll have it and it will work good enough- cheaper than gas/time driving 4 hours.
