C5 Alternator
Old May 5, 2010 | 12:49 PM
rbrtclk's Avatar
rbrtclk
Default C5 Alternator
2002 Corvette convertible, manual transmission. What alternator is on my car, who makes it, and are rebuuild kits available? Also, if no kits are available does anyone know where to get bearings for this alternator?
Old May 5, 2010 | 12:50 PM
lucky131969's Avatar
lucky131969
There are a few threads on this. Check with local shops(yellow pages), etc. You can have it rebuilt at a fraction of the cost of new.
Old May 5, 2010 | 02:58 PM
nkawtg72's Avatar
nkawtg72
Cruising
also, be sure to read the threads carefully. i could be wrong but i think i read somewhere you have to be super careful about replacing the alternator (if you end up doing that).
something about the stock alternator has some chip on it, and if you don't put the correct alternator in the DIC will start kicking out all kinds of error codes.
again, not speaking from experience on this, just something i think i read somewhere.
i'm sure someone can easily verify whether i'm correct or not.
Old May 5, 2010 | 03:21 PM
rbrtclk's Avatar
rbrtclk
I am aware of the problems with replacement alternators, that is why I want to just replace the bearings.
Old May 5, 2010 | 03:25 PM
dougbfresh's Avatar
dougbfresh
The guts are mostly from some French outfit I think, if you don't get the correct alternator that reports back to the car right, you'll get "Charge Systems Faults"
Old May 5, 2010 | 05:17 PM
wcsinx's Avatar
wcsinx
According to Bill Curlee, who thoroughly corrected me here ...
http://forums.corvetteforum.com/c5-t...showed-up.html
The goofy French alternators were only used in 97-99.
Old May 5, 2010 | 06:42 PM
rws.1's Avatar
rws.1
Evil-Twin knows of what he writes....
Old May 6, 2010 | 12:29 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
ET is the Forum alternator expert but,,,most local starter alternator repar shops will be able to service your alternator with the correct parts and at a significant cost savings.
BC
Old May 6, 2010 | 11:26 AM
rbrtclk's Avatar
rbrtclk
Is the alternator in a 2002 rebuildable by a DIY'er. What is a good source for bearings and other parts. Also, what is the amperage and model number of the 2002 alternator?
Old May 6, 2010 | 11:53 AM
wcsinx's Avatar
wcsinx
Yours is a 140a.
The part # you could get from any dealer, or I'm sure the guys at GMPartsDirect would be happy to help you.
Old May 6, 2010 | 02:04 PM
socalman's Avatar
socalman
St. Jude Donor '10
that large auction site, there's a guy there that has it all. Got bearings, brushes and volt reg for $20 delivered. Takes 15 minutes to rebuild after removing from the car.
To C5 Alternator
