oil pressure
Old May 4, 2010 | 02:13 PM
raymondh's Avatar
raymondh
Default oil pressure
..Anyone know what the normal oil pressure range should be for a c5 with about 86,000 miles. Thanks in advance.
Old May 4, 2010 | 02:14 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
What pressures are you seeing?
Old May 4, 2010 | 02:16 PM
raymondh's Avatar
raymondh
Most of the time around 40, but sometimes I see as low as 25
Old May 4, 2010 | 02:18 PM
Eric D's Avatar
Eric D
You are well within the normal range.
Old May 4, 2010 | 02:19 PM
lucky131969's Avatar
lucky131969
The mileage on an engine is not a barometer for oil pressure....especially when the condition of the engine is unknown....how well maintained it is/was, etc. The pressures you report sound normal, but more specifics are needed such as: cold start, operating temp, WOT v/s cruise, etc.
Old May 4, 2010 | 02:28 PM
raymondh's Avatar
raymondh
So, in my case, when I start the car in the morning, I see 40-45 (1200 rpm). Once I get to work I see between 25-35 (1200rpm). Thanks
Old May 4, 2010 | 03:12 PM
jrose7004's Avatar
jrose7004
That's the range I see on my 45,000 mile 04.
Old May 4, 2010 | 03:13 PM
lucky131969
Sounds about right.
To oil pressure
