Not Low Enough!
Old Mar 16, 2002 | 06:56 PM
bykerboy's Avatar
bykerboy
Default Not Low Enough!
I just lowered my '97 this morning using a kit from Xtreme. The back end looks great. However after following the instructions for lowering the front I can't even tell the difference. With the back lowered it almost makes the front look like it was higher than when I started!
Any suggestions on how to get the front lower? I have about 8 threads showing on the front leaf spring bolt.
Thanks...... :confused:
Old Mar 16, 2002 | 09:46 PM
Patches's Avatar
Patches
Default Re: Not Low Enough! (bykerboy)
You need to drive that puppy for a while to let the suspension settle. It took mine about 50 miles before it completely settled to it's present height.
Ed
Old Mar 16, 2002 | 09:51 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: Not Low Enough! (Patches)
It can take up to a couple of hundred miles to fully settle. I'd give it some time and then make some adjustments.
Old Mar 16, 2002 | 11:21 PM
AUandAG's Avatar
AUandAG
I only dropped 3/8" on the RF and 5/8" on the LF. This is after several weeks and a few hundred miles. The rear dropped about 1 1/4" on the stock bolts. I'm wondering if it didn't drop much in the front due to Z51 springs. Or maybe it's the Bilstein Sport shocks. Anyone have any thoughts?
Jim
[Modified by AUandAG, 7:58 PM 3/16/2002]
Old Mar 16, 2002 | 11:35 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: Not Low Enough! (AUandAG)
If it's not enough after you let it settle, then there is only one other choice if you do not want to spend big bucks on coil overs. You have to cut 2/3 of the bushing on the front, that will get you low enough, check my sig. :D
[Modified by racer44, 8:35 PM 3/16/2002]
Old Mar 17, 2002 | 09:40 AM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
Default Re: Not Low Enough! (racer44)
Yep I cut 2/3 in front and 1/3 in rear and added HAL shcoks. See sig! :D
Old Mar 17, 2002 | 11:41 AM
Racer's Avatar
St. Jude Donor '11
Default Re: Not Low Enough! (2000^C5)
Hey 2000^C5, I have to ask you, why do you have Hockey Canada pics in your sig? Not that I mind, in fact I like. :D :D I have two theories, 1. You are a Canadian working in Florida, or 2. you like hockey and only support winners, and Canadian hockey defines winners!
:D :D :smash: :smash: :smash:
Old Mar 17, 2002 | 04:15 PM
2000^C5's Avatar
2000^C5
racer44,
I am a proud Canadian, I am just down in Florida for the winters.
I am from Winnipeg and am always back in for the summers. :cool: I have been to Calgary a few times and have some friends that now live there. Great city! :yesnod:
Old Mar 17, 2002 | 05:35 PM
ambitin's Avatar
ambitin
I had my bushings cut 2/3 in the front and that did the trick- looks quite nice and I couldn't tell any difference on the ride quality. I wouldn't hesitate to cut my bushings again if I bought a new vette. I do have bilstein sport shocks...
Here is the stance on my car:
Good luck,
Justin
Old Mar 17, 2002 | 08:07 PM
Racer's Avatar
St. Jude Donor '11
racer44,
Lucky dog!!!!!! If you ever come to Calgary, beers on me! :cheers:
Old Mar 17, 2002 | 08:17 PM
kwik8racr's Avatar
kwik8racr
Just take the bolts out! If you want low, thats what I did, and I do have the Bilstien sports too. :D
Old Mar 17, 2002 | 11:04 PM
strypr's Avatar
strypr
do you have to drop the front lower control arm to remove the bushing ?
thanks in advance :confused:
Old Mar 17, 2002 | 11:16 PM
Racer's Avatar
St. Jude Donor '11
Default Re: Not Low Enough! (strypr)
I did using this great "how-to" page http://www.corvetteforum.cc/techtips...D=90&TopicID=1 :cheers:
To Not Low Enough!
