Spec 3 Clutch "whine"
Old May 5, 2010 | 04:29 PM
dfurnas's Avatar
dfurnas
Default Spec 3 Clutch "whine"
My new Spec 3 with 300 miles is "whining" out of 1st gear FROM A STOP ONLY. Everything else is roses. Im still breaking it in and city shiftin, sounds like someone dragging a chair across a wooden floor from a light or a stop sign when taking off. Is this normal for break in? Thanks
Old May 5, 2010 | 06:24 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Yeah its normal. Its just the chatter. Most of it maybe all of it will go away after the 500miles.
Old May 5, 2010 | 09:44 PM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
The noise is common on the spec 3. 50/50 chance it will go away.
Old May 5, 2010 | 10:20 PM
Carcass's Avatar
Carcass
My Spec2 has a couple thousand miles on it and it occasionally lets out a "groan" in first and reverse,just as it engages.
I was a little worried at first,but now it's in the "it just does that every now and then" category.
Works perfect otherwise.
Old May 6, 2010 | 07:20 AM
AU N EGL's Avatar
AU N EGL
Normal for almost all aftermarket clutches
Old May 6, 2010 | 07:36 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
Just curious, why are you using a Navy one star flag officer 's flag as your avatar? This would bother me if you are not a Rear Admiral.
Old May 6, 2010 | 07:53 AM
AU N EGL's Avatar
AU N EGL
1861 Bonnie Blue Flag http://en.wikipedia.org/wiki/Bonnie_Blue_Flag
my Political expression
" Hurrah! Hurrah!
For Southern Rights, Hurrah!
Hurrah for the Bonnie Blue Flag
That bears a Single Star!"
ie individual and states rights over federal rights
I could use the Gadsden flag http://www.foundingfathers.info/stories/gadsden.html
OK back to topic
Old May 6, 2010 | 09:07 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
" Hurrah! Hurrah!
OK back to topic
Political expression aside, the symbol you are using as you avatar is a rank insignia for a US Navy Rear Admiral Lower Half. I believe that thirty years of service to the Nation and the US Navy entitles me to be annoyed by its use for anything other that its intended purpose.
This is not forum banter or a game for me. I'm asking you and the moderators that out of respect for those who earn the right to fly that flag to remove it. Thank you.
http://tmg110.tripod.com/usn2.htm
Old May 6, 2010 | 09:43 AM
mmartinez's Avatar
mmartinez
Default Avatar
Its a free country!
Old May 6, 2010 | 11:47 AM
Jon@Texas-Speed's Avatar
0Jon@Texas-Speed
Former Vendor
If it is doing it on a slow release, I would recommend going out and beating on the car a bit. Get the disk hot and clean off and glazing that might be on it. This typically takes the whine/groan sounds out of them. After talking with a couple different manufacturer's it is caused by the disk being glazed over.
Jon
Old May 6, 2010 | 12:29 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
You are also asking a citizen not to excercise one of his constitutional rights.
He has the right to even wear a Rear Admiral's uniform in public if he wanted to.
Old May 6, 2010 | 05:52 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
You are wrong on both accounts, federal law specifically prohibits this under Title 10 of the US code. Bill, you are a retired Senior Chief, why aren't you chiming in?
Old May 6, 2010 | 06:00 PM
0331MARINE's Avatar
0331MARINE
The flag does have more than one meaning, and he said what the reason behind it was. I dont see a problem with it. BACK TO THE QUESTION. Like everyone else said give it some more miles and it should get better. I am about to put a SPEC 3+ in mine.
Old May 7, 2010 | 12:16 AM
0331MARINE's Avatar
0331MARINE
Ill let you know how my SPEC 3+ does. It just got here a few hours ago!!!! Nothing wrong with the flag man! Im from the South and I know what it stands for!!!
Old May 7, 2010 | 08:25 AM
AU N EGL's Avatar
AU N EGL
Change / flush the clutch fluid too.
Old May 7, 2010 | 09:24 AM
81c3's Avatar
81c3
Jon
This does work, but its only a temporary fix..... at least for my Monster Level 3. The glaze builds back up a short time after with normal street driving.
To Spec 3 Clutch "whine"
