Where to buy '97 EBCM?
Old May 5, 2010 | 10:11 PM
ripleyrr's Avatar
ripleyrr
Cruising
Default Where to buy '97 EBCM?
Finally giving up,,,, did all checks, cleaned grounds, swapped harnesses, replaced hub assy. (no help), checked for signal at EBCM connector (was good), checked ohms reading at EBCM connector (was good). Took EBCM off again and looked for anything suspicious (nothing). Getting 1221 DIC.
Where is best pricing for EBCM for '97 (mounted in rear)?
Thanks for any help with this.
Old May 5, 2010 | 11:02 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you remove the main EBTCM connector can you read the wheel sensor from the connector??? It will be pins 15 and 31
My guess is you have a bad female pin in one of the connectors. Most likely the on on the frame that the jumper harness plugs into.
They wind up looking like the one on the right (BAD) Left is NEW:
IF,,,,you have to purchase a new one,,,Gene Culley has the best price www.gmpartshouse.com
BC
Old May 6, 2010 | 07:36 AM
ripleyrr's Avatar
ripleyrr
Cruising
Yes Bill, I checked at the connector and had the AC signal. Also shorted out the connector at the sensor plug next to wheel and had good ohms reading (about 0.5). Shook wiring harness, etc. No change. Swapped left and right harness. Bent female mating connectors as your info suggested. Put new hub assy on right and put old right hub on left where bad signal supposedly is. Thanks for your reply
Old May 13, 2010 | 10:19 AM
Rhode Warrior's Avatar
Rhode Warrior
Originally Posted by Bill Curlee
IF,,,,you have to purchase a new one,,,Gene Culley has the best price www.gmpartshouse.com BC
Just got off the phone with Gene Culley. The EBCM is discontinued.
Old May 13, 2010 | 01:11 PM
trussme's Avatar
trussme
Default you might try these 3 options ...
maybe you can get a REBUILT EBCM from these folks:
http://stores.shop.ebay.com/Digital-.../Homepage.html
http://www.autoecu.com/?gclid=CO-ozv...FR4UagodWwilqQ
http://www.speedometerrepairguy.com/
Old May 13, 2010 | 01:13 PM
trussme's Avatar
trussme
you also may want to call Fred Beans to see if they have one..
To Where to buy '97 EBCM?
