Slave Cyl "Quick Disconnect" ?
Old May 6, 2010 | 07:00 PM
SmoothFRC's Avatar
SmoothFRC
Default Slave Cyl "Quick Disconnect" ?
Ok, so i feel like i just cannot catch a break with my clutch job.
So i have the driveline bolted up and wanted to bleed the slave before putting the cradle back on, etc.
How does one re-connect the master to the slave? i read someone using vise grips to connect them, but wanted some other input before i wreck it.
Thanks,
John
Old May 6, 2010 | 07:42 PM
02 super sport's Avatar
02 super sport
I'm at the same spot with my install.
Old May 6, 2010 | 08:39 PM
Carcass's Avatar
Carcass
Just push it straight in till it clicks.
There is NO slack in the lines,so if they're not straight,they won't reach-and it's hard to keep them straight,hang on to them,and push against the spring tension at the same time.
Just keep trying,they'll go
Old May 6, 2010 | 09:25 PM
HP_Addict's Avatar
HP_Addict
it just pushes back in. Loosen the bleeder screw on the slave to relieve some pressure. the lines must be straight.
Old May 7, 2010 | 08:47 AM
SmoothFRC's Avatar
SmoothFRC
so you dont have to play with the quick disconnect or anything? just line it up and push er in?
Old May 7, 2010 | 09:20 AM
JVetthead's Avatar
JVetthead
Do Not Pull on the master side of hose to hard it will break the plastic fitting hose connects to on master.... been there
Old May 7, 2010 | 02:01 PM
chevy406's Avatar
chevy406
Originally Posted by SmoothFRC
... just line it up and push er in?
Exactly. Once you get it popped together you will say "That was Easy".
Old May 7, 2010 | 05:53 PM
SmoothFRC's Avatar
SmoothFRC
Yup, that is exactly what i said Guess i did not have it lined up straight yesturday, but went out today and it clicked right in.
Thanks guy's....
Old May 7, 2010 | 05:59 PM
81c3's Avatar
81c3
Thanks guy's....
It just works like that sometimes. I cant count how many times I've tried to do something for an hour, get pissed, shut the light in the garage, come out the next morning and in 5 minutes it worked out.
To Slave Cyl "Quick Disconnect" ?
