Are bcm,s from different years compatible?
Old May 7, 2010 | 02:24 PM
phil068's Avatar
phil068
Default Are bcm,s from different years compatible?
I have a 2000 that needs a new bcm. I am trying to find one used as they are very expensive new. Do I need one that came from a 2000?Upon checking the corvette parts guide I found that 1997-2000 model years each have thier own part number and 2001-2002 share the same part #. The 2000(part#10304930) is very close to the 01-02 (part # 10304931) while the other model years are quiote different. Want to make sure if I buy I used one that I will be able to use it. Any info would be helpful
If anyone happens to have a used bcm for sale , preferably from a 2000, let me know what you want for it. Thanks
Old May 7, 2010 | 07:49 PM
TurboBerserker's Avatar
TurboBerserker
It will work, but you may have to do a bit of wiring to make all your options work. I put a 2001 BCM in my 97 (so I could shut of the TPMS error msg) and had to move one wire to power the EBCM.
