Under Drive Pulley
Old Mar 17, 2002 | 10:04 AM
Als98C5's Avatar
Als98C5
Default Under Drive Pulley
I'm about to take the plunge and install a cam shaft, and LS6 intake manifold and was wondering about the under drive pulley. First, who has the pulley in stock ready to ship? (the car goes under the wrench on 9 Apr). Second, does it come with belts? Third, if a belt breaks 6 months from now, how can I get a replacement?
Old Mar 17, 2002 | 10:58 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Under Drive Pulley (Als98C5)
Many of the Forum Mall vendors have the pulley in stock. Some of them do come with belts and the bolt to install it. If you need replacement belts in the future, they are available at any automotive store in your area.
vetterdstr :cheers:
Old Mar 17, 2002 | 06:13 PM
davidfarmer's Avatar
davidfarmer
Default Re: Under Drive Pulley (vetterdstr)
you can get pulleys at any autoparts store. They have incremental lengths to fit pretty much every variation. On my car, I run a 10% underdrive aluminum pulley from ATI (without the A/C pulley), and due to it throwing belts, I had to replace the stock tensioner with the Katech tensioner.
Dave
Old Mar 17, 2002 | 07:17 PM
RHILL's Avatar
RHILL
Default Re: Under Drive Pulley (y2khardtop)
Thanks Dave and Vetterdstr
You guys answered what I needed to hear thanks
Old Mar 17, 2002 | 07:31 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Many of the Forum Mall vendors have the pulley in stock. Some of them do come with belts and the bolt to install it. If you need replacement belts in the future, they are available at any automotive store in your area.vetterdstr :cheers:
Well stated!
Old Mar 17, 2002 | 09:45 PM
Als98C5's Avatar
Als98C5
Are you all saying that you use the stock belt and the tensioner takes up the slack?
Old Mar 17, 2002 | 10:28 PM
whiteboy's Avatar
whiteboy
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Under Drive Pulley (RHILL)
What do the under drive pulley's give you on the dyno? Are they worth the money and time and labor?? What purpose do they serve?? Especially for street and strip? Thanks in advance for your help. Whiteboy :chevy
Old Mar 17, 2002 | 10:40 PM
vetterdstr's Avatar
vetterdstr
Default Re: Under Drive Pulley (wallstAL)
thanks Al. :)
When the pulley is installed the stock tensioner is used. You will get HP gains with the pulley. If it is worth it or not... is up to you. ;)
vetterdstr :cheers:
Old Mar 18, 2002 | 05:18 AM
davidmax's Avatar
davidmax
In stock now at XTREME (480)517-4969.Good Luck David Smilovic.
Ask For Nate its a real nice piece instant sotp pony gain.
To Under Drive Pulley
