Passenger Window / Lock problem
Old May 8, 2010 | 05:24 PM
rick4248p's Avatar
rick4248p
Navigator
Default Passenger Window / Lock problem
Recently had a little problem that I'm not sure if its a car problem or a setup problem.
I stopped for gas, got out of car with key still in ignition but friend sitting in passenger seat. He was lowering window as I turned off key to get out. After fueling up I had a series of warnings, security, service active handling, service traction control, service tire pressure monitoring. This scared me but everything was running fine. Pulled over, turned off car, restarted and everything seemed fine,
Except, passenger window would not go up or down. Passenger door lock would not work either. Anyhow, after reading manual and then replacing fuses on right door, Right Door Control Control Module and Right Door Power Feed, interestingly enough, the window and locks work from both doors
BUT, only when the passenger door is OPEN. I have done this multiple times to confirm. Am I missing something in my options setup ? Is there a reset ? The problem is not huge, I can still drive the car, but it does have me confused.
Any ideas or suggestions ? Thanks, everybody for listening
Old May 8, 2010 | 05:44 PM
lucky131969's Avatar
lucky131969
All the fuses you replaced were blown?
Check your codes:
http://www.c5forum.com/ayc/dtcdic.php
Old May 9, 2010 | 11:01 AM
rick4248p's Avatar
rick4248p
Navigator
No the fuses were fine, just thought I change as precaution. Regarding the codes, I tried getting them from local parts store, the reader was only giving an ERROR message. Need to try elsewhere.
Have tried windows and lock several more times, still the same, it only works when the door is fully open, wierd
Old May 9, 2010 | 11:25 AM
lucky131969
check the wiring in the right door accordian tube.
To Passenger Window / Lock problem
