lowering bolt/nuts
Old May 8, 2010 | 05:27 PM
Crow Hunter's Avatar
Crow Hunter
Default lowering bolt/nuts
If I am standing at the rear, looking downward, which direction should I turn the height adjustment nuts to lower - CW or CCW?
Also, what size is the nut? The instruction manual is no help. It shows the nuts alright, but doesn't state which direction to turn to raise or lower, nor the nut size. Typical manual.
Thanx in advance, guys!
Old May 9, 2010 | 12:33 AM
sperkins's Avatar
sperkins
Loosen the nut to lower the car. CCW
VET-005's Avatar
VET-005
anti clock wise. The direction that lengthens the bolt like you are un doing it.
Old May 9, 2010 | 03:31 AM
socalman's Avatar
socalman
St. Jude Donor '10
Size of wrench 21mm or 13/16 (same/same). Grab your wrenches (everything bigger than 18mm and/or 3/4 cause you're going to need 2 of them. There hasn't been a manual made that tells you what size tool you need for wrenchin on a car.
You will need a backup wrench to hold the bolt head under the spring.
Old May 9, 2010 | 02:43 PM
Crow Hunter
Many thanx guys! I knew some of y'all knew the answers.
Old May 15, 2010 | 05:21 PM
blackc5vert's Avatar
blackc5vert
What does cw andccw mean
Old May 15, 2010 | 05:23 PM
hotwheels57's Avatar
hotwheels57
clock wise and counter clock wise...
Old May 15, 2010 | 07:13 PM
GettnBetter's Avatar
GettnBetter
Rightsey tightsey, leftsey losey but loose at extremes sometimes isn't better.
To lowering bolt/nuts
