I'm about to do a H/C and am wondering if when the engine is reassembled what can I have installed to make the replacement easier?
I'm no mechanic, but I know that changing out the camshaft is a very difficult endeavor. According to LS1Howto one has to remove the steering assembly as well as the radiator. From what I understand is this is required because you have to remove the one piece timing chain cover plate.
What parts can be installed that will make the camshaft replacement a little easier? What disassemble processes can I avoid by installing these altered parts?
There are companies that supply a split type timing chain cover that saves you from pulling the steering rack and harmonic damper. Personally I wouldn't bother as the split covers have their own issues. Unless you plan on swapping cams a LOT, I'd stick with the stock setup.
I prefer to drop the cradle and support he engine on stands, but that's an unpopular thing on this particular forum. It will save you time and frustration though.
Is there any sort of write up on this? Sounds much easier to me.
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Its not that bad. I did mine in about 6 hours under a car port! Just watch out for the oil pump o-ring. Mine got cut and I didnt know it, had to take everything back off to fix it.
^^^Ouch, Hey Will it's not a bad job at all. I've done a couple to say the least. If you need help shoot me a PM and I can help you out buddy
So I guess it was more like 12 hours No, really, That's a lot of work to do twice. It took me 3 months to do my Heads/Cam. Starting the job the first week in January probably wasn't a good idea though- too damn cold.
It only took about 2 hours to do it the second time!!!
I agree, OUCH. Hey Brandon, if I understand Kushan correctly you may be helping with my heads and cam. I just think if there is anything like a half plate or etc. Now would be the time to install them. I want the removal to be as painless as possible incase I need to reverse the mods.
get the car on stands, put stands under the motor (I used a 2x12 across the oil pan) remove the A arms, motor mount bolts, and cradle bolts, drop cradle. Remove the brake calipers if youw ant to pull it out of the way.
Hey Will, yeah I'll be helping Kushan out on some projects these next couple of weekends. As far as the 2 piece timing cover they do make them but they are pricey. I wouldn't worry about the removal process if you wanted to go back to stock
