C5 Pop up Headlight Problems
Old May 11, 2010 | 04:52 PM
01lucasr's Avatar
01lucasr
Default C5 Pop up Headlight Problems
When I tunred my headlights on last night the drivers side only raised half way while the passenger side came all the way up. I checked the motor for loose screws/bolts and found nothing. With the headlights turned on, I tried raising the light manually and met to much resistance. You can manually lower it just not raise it. I need some advise on what maybe the problem and a possible solution on repairs.
Old May 11, 2010 | 06:29 PM
VetteSiNz's Avatar
VetteSiNz
Replace the gear inside - easy to do. Replace it with brass gear from Rodney Dickman (www.rodneydickman.com) not with the original plastic gear. I bought mine from Rodney in EBAY - and replace them both left and right side.
Old May 12, 2010 | 02:30 PM
01lucasr's Avatar
01lucasr
Thanks for the information. I have ordered the gears for both sides from Rodney (the link above). Does anyone know where on the forum that you can get step by step instructions on this repair?
Again thanks for the HELP.
Old May 12, 2010 | 02:46 PM
lucky131969's Avatar
lucky131969
Lot's of good info up top......
http://forums.corvetteforum.com/c5-t...with-pics.html
Old May 12, 2010 | 03:15 PM
MG RED 99's Avatar
MG RED 99
Mine have been working for years with the brass gear from Rodney. The gears may also come with instructions too, I can't remember. very easy to fix. Just take your time and reassemble correctly and you will be fine.
P.S. certain earlier model years of the C5 came with the gear covers screwed on, which means you don't have to split the cover and epoxy it back together, which is not that big of a deal. On my 99 it was the screwed on type which makes it slightly easier. just in case you see that step in the instructions.
Another note to consider is in case you do this now, is don't raise the headlamps while cruising at high speeds. the shock of the air resistance is hard on the gears for future note. Good luck
To C5 Pop up Headlight Problems
